I've tried to put together a release of Android with Market working for the Joggler. This release is based on the release from our chinese friend (mijuu @ mporting) s but with some tweaks to make it work better/easier with our jogglers..
That said you still need to some some tweaking to get the market working as I couldnt find a way of wiping/replacing my google account once configured without removing the market app.. which defeats the purpose..
This current release features :
- English menus
- Google Apps Installed (Maps, StreetView etc)
- Google Market Partially installed
- AndAppStore installed
- AppBrain Store installed
- Astro File Manager installed
- Drop Box install
- Market Enabler Installed (not sure its needed though...)
- Launchpad Pro install and configured with some effects
- Checkout the Hidden Apps option in general settings, allows u you hide camera, chinese app store etc..
- WinAmp Installed
- YouTube Installed (but slightly jerky in its usage)
- Titanium Backup installed (used for Market enablement)
- Clock Sync configured to execute on boot
- Clock Widget Installed onto Main Screen with Weather
- Volume Widget Installed onto Main Screen
- Google Finance Widget available
- Subsonic Music Streamer
To install.
1. Download my image from http://italianknows.com/joggler/android ... _Angel.rar
2. unrar file to a directory, will create a android_joggler1.1_angel.img , you will need to download winrar (http://www.rarlab.com) for this
3. Use https://launchpad.net/win32-image-writer to write the image to a memory stick of at least 4Gb
edit 4-Jun-2011 : Make sure you use the latest, 0.3 currently, of the software.
4. Boot in joggler
5. Connect to network, if possible use cable not wireless .. Wifi should work but I havent tried it....
6. Click on 4x4 grid to get to Apps Draw (note the cool graphics
![Smile :-)](./images/smilies/icon_e_smile.gif)
7. Sign In/Create account
8. Accept Market Terms of use etc..
9. Market should then work, but with limited Apps.. no uk apps etc..
10. In a minute or so you'll see a alert in the bar (triangle) asking you to accept permissions, you need to do this.. Continue the following steps whilst this filters through... (drag the notify bar down, select it and accept)
11. Go to Settings/Applications/Manage Applications and force stop both Market and Google Framework Apps
12. Go to Titanium Backup, Backup/Store tab/ Select ONLY Google Framework Apps and Wipe Data
13. Back to Home screen, and run Market. At this point you should get an error (good!), press OK
14. Reboot joggler, you can either pull the plug or use the Chinese Power App and use the first option (prefered less wear+tear on plug)
15. Once the joggler reboots wait 1 minute and retry market app, accept T&C and hopefully smile
If it gives an error when you run market again, then maybe you didnt wait 1min
1. Reboot
2. Repeat steps 11 onwards
Current Wish List
- A way of exiting full screen apps (use button savior below)
- Something like lastfm.. damm they want cash$$ now.. although not too much
- Decent music streamer for radio stations...
Anyone tried squeezeplay?
Hope this works out for all..
Please let me, and others, know how it works out for you guys.
Angelo
edit : 27-May-2011 : Button Saviour (https://market.android.com/details?id=com.smart.swkey) gives you softbuttons which are useful for exiting full screen apps
