atinwi
Post by atinwi »
I know I'm irritatingly thick but...
How do I do this?:
If you wish to write an alternative image file, such as SqueezePlay OS:
2. Simply copy both the .img.gz and .img.gz.md5 files to the reflash directory on rfl-boot.
thanks for any reply
Yes.
You can do this in Wintel if you want; its just a copy and paste of the image files into the reflash directory.
he Joggler will shut down when it is complete.
buffalosoul
Post by buffalosoul »
ignore / all fixed
Imagewerx
Post by Imagewerx »
Hopefully I interpret the instructions on Roobarb's website correctly.I want to install the whole Squeeze O/S onto my Joggler,but first I have to make the reflash USB stick.It says to download the reflash script into the reflash directory,but I get it as a page of text.Do I just copy and paste this to a text document and put it into the reflash directory,or is there more to it than this? Also it says I need this.......
http://o2.openpeak.co.uk/firmware/app-o ... eimage.tgz
.....but the link seems to be dead.Can I get this from anywhere else?
Apologies if these questions have been asked before,I did take a quick read through some of the previous posts and couldn't see them anywhere.
Imagewerx wrote:Hopefully I interpret the instructions on Roobarb's website correctly.I want to install the whole Squeeze O/S onto my Joggler,but first I have to make the reflash USB stick.It says to download the reflash script into the reflash directory,but I get it as a page of text.Do I just copy and paste this to a text document and put it into the reflash directory,or is there more to it than this? Also it says I need this.......
If you've successfully made the reflash stick, you should see a volume with a directory in it called reflash.
If you want to put SQPOS onto your Joggler's internal memory, you just need the SqueezePlay image file and it's .md5 checksum file. Make sure you download the correct ones (SqueezePlay OS v2.06 for OpenFrame 1 Internal Memory if it's a Joggler). Pop them both into the reflash directory on the stick, eject the stick, pop stick in the side of Joggler, power on Joggler, watch.
Imagewerx
Post by Imagewerx »
Ok thanks for the prompt answer. So this will totally erase the original o/s and leave me with Squeezeplayer complete with Logitech media server? Also do the files I put inside the reflash folder have tobe zipped or unzipped?
Imagewerx wrote:Ok thanks for the prompt answer. So this will totally erase the original o/s and leave me with Squeezeplayer complete with Logitech media server? Also do the files I put inside the reflash folder have tobe zipped or unzipped?
Just exactly as they are from the website - one will be .tgz, the other .md5. Internet Explorer sometimes tries to auto-decompress, which is naughty.
It will indeed erase the original OS. If you want to run Logitech Media Server, I really don't recommend installing it on internal memory. There's just not enough space.
Imagewerx
Post by Imagewerx »
Is LMS not included in that lot then,do I have to download and install it separately?
LMS is not included. You have to install it separately.
If you use a usb install, then I'd recommend doing the Spqos install first. Ideally, you should then expand the usb to use the full usb size for any subsequent LMS install.
Imagewerx
Post by Imagewerx »
castalla wrote:LMS is not included. You have to install it separately.
Ok thanks,got that.
Now this bit.Made the reflash tool and I have the following on it,is this correct?
In the reflash directory,I have this lot...
It goes to start the install and says 'Stalling for network (up to 60 seconds)',then says 'unable to connect to 02 firmware server at openpeak'. It shows a few other messages about needing a wired connection etc,then switches itself off.
I'm guessing it just can't find the stuff I've put into the reflash folder? I've read some of the posts from the start of this thread,in particular the ones about making sure my browser doesn't rename the file extension.I've got 'sqpos206_of1 .img.tgz' and 'sqpos206_of1.img.gz.md5' once I've set it to show full file extensions.
jimeney
Post by jimeney »
Remove jogglerflash.sh as this is only required to download the Openpeak firmware. Looks like you've decompressed the sqpos206_of1.img, you don't need to do this, so put the .img.gz file back instead.
In the reflash directory there should be the following
sqpos206_of1.img.gz
That's all there is to it hopefully
I still wonder why you are persisting wih the internal install. The usb sqpos is much easier and will work fine for an LMS install.
Imagewerx
Post by Imagewerx »
jimeney wrote:Remove jogglerflash.sh as this is only required to download the Openpeak firmware. Looks like you've decompressed the sqpos206_of1.img, you don't need to do this, so put the .img.gz file back instead.
sqpos206_of1.img.gz
Thanks for the answer.It wasn't decompressed,it was just set not to show the file extension.The reason it couldn't find it was that I'd inadvertently put a space into the file name,took it out and it worked just fine.
Imagewerx
Post by Imagewerx »
castalla wrote:I still wonder why you are persisting wih the internal install. The usb sqpos is much easier and will work fine for an LMS install.
I'll need a USB hub for this won't I?
Also I can't find specific installation instructions.Do I just use the one directly From Logitech? If so do I have to use the reflash tool or some other way?
A hub is not essential.
The usb SQPos exists on a usb stick - plugged into the Joggler. You simply write the image to a usb memory stick (http://birdslikewires.co.uk/download/jo ... ext.img.gz). The Joggler will boot from the usb stick into SQPos - do the setup.
To install LMS - there's an option in SQP to install LMS - Settings > Advanced > Additional Features > Logitech Media Server.
An alternative way to install LMS: login to the Joggler as root using PuTTY. Download the LMS file and install. You need to understand some basic linux commands to do this.
Just to let folk know that I am working on an updated version of the Reflashing Tool. Now that OpenPeak have stopped hosting the old image file, things need refreshing and the help text could be a made a little more descriptive.
I shall let you all know when it's done!
It is done!
Shiny new version - with the ability to do EFI flashing as well (though I've not written the instructions for that yet).
The new thread for the new version is here.
Locked
