I installed LMS 7.7 on my WD MyBookLive by SSH-ing into it & typing:
cd /DataVolume/shares/Public
aptitude update
wget http://downloads.slimdevices.com/LogitechMediaServer_v7.7.3/logitechmediaserver_7.7.3_all.deb
dpkg -i logitechmediaserver_7.7.3_all.deb
Unfortunately LMS hangs while scanning my music collection and I was going to try upgrading to 7.8 ( http://downloads.slimdevices.com/LogitechMediaServer_v7.8.0/logitechmediaserver_7.8.0_all.deb )
Would I need to uninstall the 7.7.3 version first? If so, how would I do it?
Ta
Help with SSH commands for uninstalling please!
Re: Help with SSH commands for uninstalling please!
Thinking it would be something like:
Then to check removed package it would be:
seeing an rc means removed OK.
dpkg -r logitechmediaserver_7.7.3
dpkg -l | grep 'logitechmediaserver_7.7.3'
Normally, it isn't necessary to uninstall. A new install should simply replace the existing version.dwl99 wrote:I installed LMS 7.7 on my WD MyBookLive by SSH-ing into it & typing:
aptitude update
wget http://downloads.slimdevices.com/Logite ... .3_all.deb
Unfortunately LMS hangs while scanning my music collection and I was going to try upgrading to 7.8 ( http://downloads.slimdevices.com/Logite ... .0_all.deb )
Ta
Of course there's always a chance it doesn't work!
Thanks guys, it turned out to be:
Job done! Although I bet the server will still hang while scanning
