LMS on Zyxel NSA310 - Update-able manually?
I''ve recently acquired a Zyxel NSA310 NAS which runs LMS 7.7.1 via it's own installation package (the most up-to-date available with most up-to-date firmware). Does anyone know a way of manually updating it to a 7.8 nightly? I can telnet in and get to the LMS files. Would I be able to overwrite some of the files with those from the appropriate nightly distro? If so, which distro would I need and which files are the 'workings' and which are the launch scripts (which I guess are specific to the Zyxel NAS
It's full details are:
Logitech Media Server Version: 7.7.1 - r33735 @ Mon Nov 28 16:49:58 MST 2011
Operating system: Linux - EN - utf8
Platform Architecture: armv5tel-linux
Perl Version: 5.10.0 - armv5tel-linux
Database Version: DBD::SQLite 1.34_01 (sqlite 3.7.7.1)
Re: LMS on Zyxel NSA310 - Update-able manually?
You might find this forum can give you the answer http://forum.nas-central.org/viewforum. ... 372cfec785
M@rty
Post by M@rty »
Hi i have the same issue, but i can t find any info on the suggested forum. Did you have any luck in updating lms and, if yes, could you tell me how uou did this? Thanks!
