Re: Android 4.04 build - now fully working!
Post by hawsey » Fri Mar 08, 2019 9:08 pm
I am messing with SDR radio on Android ICS on my Joggler and came across an issue where the Play Store says the Joggler is not compatible however if I side load the APK , than it works ( no all features )
I want to purchase the full app and not the trial but it doesn't let me buy on the Joggler . Is there a way to fool the Play Store in to showing the app as available ?
@dwl99 maybe you have an idea . :-)
Any help greatly appreciated .
Post by dwl99 » Sun Mar 17, 2019 1:59 pm
Hi Gary,
Buy it on your Android phone, copy the apk file to your SD card, upload it to Dropbox on your phone then install it from Dropbox on the Joggler. Simples!
PS there's a small chance it won't be compatible with the Joggler's x86 architecture or Android version in which case you'll get a parsing error. If this happens hopefully you'll discover it quickly enough to get a refund on the app purchase from Google Play store!
Post by hawsey » Sun Mar 17, 2019 2:06 pm
Cheers dwl99 , I shall try that and report back :-)
dwl99 wrote:Hi Gary,
Post by dwl99 » Sun Mar 17, 2019 2:28 pm
If that doesn't work you can try editing the Joggler's build.prop so it can masquerade as a phone but remember to back up an image of the USB drive first in case you break it!
Post by hawsey » Sun Mar 17, 2019 2:52 pm
Cheers do you know if there is a decent version of KITKAT at all ? Or this ICS , just with it being newer .
Post by dwl99 » Sun Mar 17, 2019 3:09 pm
The Kitkat version is unstable & will not boot after being shut down.
Post by hawsey » Sun Mar 17, 2019 3:31 pm
Ok cheers that's a shame .
Post by hawsey » Sat Mar 30, 2019 11:49 am
I got this working by doing as you suggested :-) thanks
Post by dwl99 » Sat Mar 30, 2019 6:41 pm
Great!
