I'm trying to clear out some tech I no longer need and I seem to have a couple of RT2770F cards kicking around (the ones that are the default card in the Joggler). One is perfectly ordinary and will just drop in to the internal USB port, the other has a short cable in place of the normal USB plug. Can't remember why I did this, but there was a reason at the time - works just fine IIRC.
Just leave a message on here if you're interested. Not looking for anything for them, though if you'd like to leave a little donation it always helps with the hosting!
GONE: RT2770 Wifi Cards
Re: FREE: RT2770 Wifi Cards
I think some of the betting shop Jogglers did not have a wifi card in them. So these may be of interest to people with one of them. I think is was a mis-description if you received a Joggler without a WiFi card, and you wouldn't know till trying to use wireless...
HI,
I picked up a couple of Jogglers that have had their Wifi removed by previous owners for some obscure reason.
I'd therefore be interested in one/both, depending on whether others want one or not.
Thanks,
Jim
Thanks,
Jim
Not had any takers so far, so you're welcome to one or both! Drop me a PM with your details and I'll mail them out. I have the antennae as well, so I'll pop them in the post too.jim_lewis1 wrote:I'd therefore be interested in one/both, depending on whether others want one or not.
