*IMPORTANT* database rollback
Due to a moderartion accident that involved three thread deletions, the forum database was rolled back to the last backup (18:04 GMT, 2014-01-03).
I have a backup from the database before the older backup was restored so I could manually restore the 2 posts and any PMs that were made between 6pm 2014-01-03 and 05:05 2014-01-04. Let me know if you want me to do this. Apologies for any inconvenience caused by this.
Re: *IMPORTANT* database rollback
Hi BuZz,
I am missing at least 1 important pm from hawsey from yesterday with some parcel tracking info - could you restore that?
Thanks for your help!
Heiner
Heiner
I have restored PM's to how they were as there were a a handful made since the earlier backup. Please confirm you have the missing PMs. thanks
Yes - its there again!
Thank you, BuZz
Thank you, BuZz
BuZZ, I,m missing the thread about 24/9696 playing files?
could it have something to do with the forum rollback?
http://www.jogglerwiki.com/forum/viewto ... ed+digital
this link
this link
Thanks for the heads up. Yep there have been more topics deleted in december also :/
I keep database backups for 8 weeks, so I will get an older database and attempt to reconstruct manually. this is going to take some time though.
Ok, so not too bad to get the stuff back. I'll detail here for reference - might be useful to someone. I take backups very seriously, so getting the old database is not a problem. I use http://www.nongnu.org/rdiff-backup/ with 8 weeks of reverse increments (and 2 offsite backups a day).
A look at the moderator logs tells me the topics were accidently removed on 2013-12-28 in the afternoon. My backups run morning and evening, so I did
rdiff-backup -r2013-12-28T07:00:00 username@backupserver::path/to/database/backup.sql.gz /root/backup.sql.gz
I then loaded a temporary database with the old backup. A quick look at the phpbb schema and documentation tells me I need to restore
(excluding things like topic subscriptions etc which are not important)
the moderator logs tell me the topic title. So for each topic I did a
I also got the name of the attachments as I will need to restore them from backup also (not yet done)
phew. everything seems ok. I will go through the moderator a log a bit more and make sure i didn't miss anything.
phpbb_topics
phpbb_posts
phpbb_attachments
select topic_id from temp.phpbb_topics where topic_title="title we want";
insert into liveforum.phpbb_topics select * from temp.phpbb_topics where topic_id=topic id above;
insert into liveforum.phpbb_posts select * from temp.phpbb_posts where topic_id=topic id above;
insert into liveforum.phpbb_attachments select * from temp.phpbb_attachments where topic_id=topic id above;
select physical_filename from temp.phpbb_attachments where topic_id
All attachments have now also been restored.
It was me that caused the grief / issues relating to posts being deleted.
I apologize about doing this.
Over the last month or so; with the holidays et al. I would visit the forum more relating to just a quick managing look rather than posting stuff.
That said I got a bit overzealous a few times seeing much spam and tried to delete all of the spam too quickly not looking at what I was doing (er deleting whole posts).
No worries Pete. Accidents happen, and no permanent damage was done. Appreciate your help running the forum
