S/PDIF output
Re: S/PDIF output
Well I got a powerd hub and it hasnt helped.
I also checked the check_snd() function and it is identical to that list apart from "IEC958" says "Speaker", whether set to Internal sound or USB sound using P'n'P
This is the soundcard I have which is a CMedia 6206 / CM106:
http://www.ebay.co.uk/itm/NEW-USB-6-Cha ... 19c5607b3a
Can anyone link to a soundcard they know works for a reasonable price? I quite like this one to get coaxial spdif:
http://www.ebay.co.uk/itm/FANMUSIC-FM-6 ... 3cbb6a691b
but have zero confidence in that working!
Re: S/PDIF output
I wish I could post a link to the soundcard I have with optical out, but I haven't been able to find it on the web. I bought it years ago and it is actually a C-Media VOIP phone handset with soundcard function and S/PDIF out. It was dirt cheap but I can't find it, or an equivalent.
I would echo parody's plea for links to hardware that works. I would like to upgrade to something less ugly and it would also save others from making worthless purchases (I nearly bought the card that parody links to.)
Re: S/PDIF output
What returns 'amixer -c 1' command ?parody wrote:Well I got a powerd hub and it hasnt helped.
Re: S/PDIF output
With USB audio set in p'n'p and usb soundcard plugged in the following is returned
Simple mixer control 'PCM',0
Capabilities: cvolume cswitch cswitch-joined
Capture channels: Front Left - Front Right
Limits: Capture 0 - 6928
Front Left: Capture 4096 [59%] [-16.00dB] [on]
Front Right: Capture 4096 [59%] [-16.00dB] [on]
Simple mixer control 'PCM Capture Source',0
Capabilities: enum
Items: 'Mic' 'Input 1' 'Input 2' 'Mixer'
Item0: 'Mic'
Simple mixer control 'PCM',1
Simple mixer control 'PCM',2
Capabilities: cswitch cswitch-joined
Capture channels: Mono
Mono: Capture [on]
Simple mixer control 'Mic',0
Capabilities: pvolume cvolume pswitch pswitch-joined cswitch cswitch-joined
Playback channels: Front Left - Front Right
Limits: Playback 0 - 8065 Capture 0 - 6928
Front Left: Playback 6144 [76%] [-24.00dB] [off] Capture 4096 [59%] [-16.00dB] [on]
Front Right: Playback 6144 [76%] [-24.00dB] [off] Capture 4096 [59%] [-16.00dB] [on]
Simple mixer control 'Speaker',0
Capabilities: pvolume pswitch pswitch-joined
Mono:
Simple mixer control 'Speaker',1
Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front Center - Woofer - Side Left - Side Right
Limits: Playback 0 - 197
Mono:
Front Left: Playback 196 [99%] [-1.65dB] [on]
Front Right: Playback 196 [99%] [-1.65dB] [on]
Rear Left: Playback 196 [99%] [-1.65dB] [on]
Rear Right: Playback 196 [99%] [-1.65dB] [on]
Front Center: Playback 196 [99%] [-1.65dB] [on]
Woofer: Playback 196 [99%] [-1.65dB] [on]
Side Left: Playback 196 [99%] [-1.65dB] [on]
Side Right: Playback 196 [99%] [-1.65dB] [on]
Capabilities: enum
Item0: 'Mic'
Mono: Capture [on]
Mono:
Mono:
Re: S/PDIF output
Is no one else using usb audio? Considering it is very popular to use these as psuedo squeezebox touch's, I can't believe everyone is using internal speakers or the headphone socket!
Re: S/PDIF output
This looks great.
Do you know if you can leave off the power and use a coaxial socket?
Re: S/PDIF output
please could you add the spdif info and pictures to the wiki?
Re: S/PDIF output
Yes, I think you can use coaxial socket instead of toslink one.parody wrote:This looks great.
Re: S/PDIF output
No problemBuZz wrote:please could you add the spdif info and pictures to the wiki?
I'll update the Wiki ASAP...
Re: S/PDIF output
All informations are available on the Wiki (Hardware modifications)
Regards.
Regards.
Re: S/PDIF output
Great stuff, thanks for adding this to the wiki AR. Does this mean i could buy a DAC without the need for a usb sound card? Is anyone using this mod like this and if so what model did you buy?
Cheers for this.
Cheers for this.
Re: S/PDIF output
That's a tidy install. I have some optical sockets unused from my shuttle xpc if anyone wants them. I can put 'em in an envelope.
ARJunior, does the chip support microphone in, too? I have TabletPC working in XP and adding support for mic would be great.
Re: S/PDIF output
Yes, STAC9202 supports stereo microphone too but I didn't take much attention as I've no need for it.Mevi wrote:ARJunior, does the chip support microphone in, too? I have TabletPC working in XP and adding support for mic would be great.
If I remember well, you can find microphone footprint on the PCB...maybe you can try it using this capture device :
[ 0- 0]: digital audio capture
Re: S/PDIF output
I'll check that out, thanks.
Re: S/PDIF output
So does any body have any USB soundcard suggestions?
Re: S/PDIF output
Before adding toslink socket on Joggler, I used this cheap usb sound card http://www.dealextreme.com/p/c-media-vi ... ongle-8978parody wrote:So does any body have any USB soundcard suggestions?
C-Media CM108 chipset is used and you can easily add spdif output too (I've done it before modding the Joggler)
Re: S/PDIF output
Are you suggesting more soldering required?!! Suppose it's less risky than doing it to the joggler directly. Do you have details of doing it?
It's a real shame there aren't more out there using USB spdif. It's the main reason I got the joggler, and I can't stand to use the headphone out with all my flac files!
Re: S/PDIF output
Well in the absence of suggestions I have ordered a CM108 usb soundcard (same as that linked to above) and found this data sheet, which suggests soldering to pin 1 for spdif and pin 14 for digital ground should give me the the RCA SPDIF I am after:
http://www.qsl.net/om3cph/sb/CM108_DataSheet_v1.6.pdf
Would rather solder on a £3 USB soundcard than directly on the joggler, just in case I slip.
