Android Joggler
to8y
Android Joggler
Post by to8y »
Hello, I'm really new to hacking and to my Joggler and I have found out that I can put android on it, can someone help me in installing it, I need the help in a way for me to understand. I'm also very happy to install linux too, but I would prefer to have android
Also what is the most up to date version of android joggler too.
Many thanks
Re: Android Joggler
Android 4.04 is the latest working version but no video drivers viewtopic.php?f=2&t=1598
Download the image from http://www.mediafire.com/download/qcgve ... l2.img.tgz then unzip it & flash to a USB stick with Win32diskimager. The first thing to do once this build is running is install Nova Launcher and ditch Trebuchet which is full of graphical glitches. Then use Titanium Backup to remove Trebuchet. And once it's set up to your liking make sure you make a backup image with win32diskimager and do this every couple of months to be safe.
to8y
Re: Android Joggler
Post by to8y »
dwl99 wrote: Tue Dec 04, 2018 7:44 am no video drivers
What does that limit me from doing and can I use an sd card and use an adaptor?
Re: Android Joggler
to8y wrote: Tue Dec 04, 2018 8:33 am
It just means there's no Youtube & iPlayer etc. Yes you can try an SD card & adapter but you might need to try a few devices as the Joggler is quite fussy about what it will boot from.
to8y
Re: Android Joggler
Post by to8y »
@dwl99 Thank you for your help, all installed and working now!
Re: Android Joggler
to8y wrote: Tue Dec 04, 2018 9:30 am @dwl99 Thank you for your help, all installed and working now!
That was quick! You might also want to consider installing a fake GPS app as some apps insist on location services before they will work. Also a rotation manager to stop some apps opening in portrait mode.
to8y
Re: Android Joggler
Post by to8y »
dwl99 wrote: Tue Dec 04, 2018 10:22 am
I screwed up a memory stick by trying to install android on it, is there a way I can get it back to normal?
Re: Android Joggler
to8y wrote: Wed Dec 05, 2018 8:29 am
Flash this image to your USB stick with Win32diskimager to nuke it http://www.mediafire.com/file/umsf2u22x ... r.img/file then reformat it
