Usb Soundcard
Andrew1971
Usb Soundcard
Post by Andrew1971 »
Hi All
Just got hold of a usb dac/sound card for the joggler and it work's quite well for £11.99 brand new. It make's a noticeable difference from the head
phone jack. Here's the link
https://www.amazon.co.uk/UGREEN-Externa ... card&psc=1
The config I am using it on is joggler on firmware v30300,pnp 3.60 using the upnp app streaming from my Wdmycloud via wifi. I am using the 3.5mm
headphone socket. And the volume slider work's too so far so good. Hope this help's other people.
Andrew
Re: Usb Soundcard
Great deal Andrew , thanks for sharing :-) is it a DAC as well I wonder .
Re: Usb Soundcard
If it's taking input through USB and putting audio out through phono, doesn't that make it a DAC?
Re: Usb Soundcard
Yes you are right , Geggs , Itlooks good for the money , cheaper than this are the generic Chinese usb ones but I'm sure they won't be as good .
