Anyone have a schematic for Joggler USB Wireless Stick
Just curious because the little USB stick has two sets of labeled points on it.
I have utilized the 4 labeled 1-4 for a USB connection cutting the main usb part out.
Curious though about J1 which is 6 little holes of connectivity.
Right above this part is a section with 3 holes labeled 9. WPS-1, NA-2 and GND-3..
Found it:
Host Interface 6 Pin Connector (its another USB connection).
(Pin 1: v+, Pin 2: D, Pin 3: D+, Pin 4: GND, Pin 5: LED, Pin 6: RF)
Type A (optional)
Wondering if the card is a combo wired NIC and Wireless card.
It is labeled: 1244-00000538-01Z
Found some stuff here:
https://wikidevi.com/wiki/SparkLAN_WUBR-125GN
https://apps.fcc.gov/oetcf/eas/reports/ ... -WUBR125GN
