ICS 4.0.4 for Joggler alpha3 - How to install on USB?
deeinlondon
Post by deeinlondon »
How do you install ICS 4.0.4 for Joggler alpha3 on to a USB Stick?
deeinlondon
Re: ICS 4.0.4 for Joggler alpha3 - How to install on USB?
So I discovered that if format a 2GB SD CArd as FAT and then unzip the ICS_Joggler_4.0.4_Alpha3.zip file and copy the contents to the SD Card then Android will just boot and work fine BUT it appears it doesn't save any changes to the SD Card and if you reboot it's like a brand new installation
There is also a file with the name 'easy...' or similar. You need to unzip that to your stick too. Someone should be able to confirm that. I remember that from mporting.com so things might have changed recently.
