Hi again
I know this is discussed previous.
I have a 4bg usb stick with ubuntu 9.10 on it. I would like to use any free space on the usb for music/photos transferred from my Windows laptop when the usb is plugged in said laptop. I hear about creating partitions on the USB as the way to let me do this. Can someone please explain the process of creating partitions simply for me.
I have also purchased a 4gb super talent pico usb (thanks for the recommendation Buzz) which I will install Ubuntu Maverick on and will also like to use the free space.
Much appreciated.
USB - Ubuntu - free space
Re: USB - Ubuntu - free space
if you only have a 4gb stick, the downloaded image will fill it, so you would need to "shrink" the filesystem somewhat and then make a new partition as fat32 or ntfs. if you chose ext4 joggler image you should be able to shrink it with gparted on another machine easily enough. with btrfs it is a little bit more technical.
Ok thanks. If I had a bigger stick how would you go about freeing up space for music/photos etc?
And with my current sticks (4gb) how do you use gparted to shrink the image and then create a partition?
Cheers.
Cheers.
if you have a bigger stick, after writing the image you will have some free space, which you could just partition as fat32 for example. for gparted, I think there should be some online tutorials on using it to resize partitions that would be more indepth than I can explain here.
I have been struggling to partition any usb stick on windows - diskpart wont allow telling me there is insufficient space - all usbs are empty though!
So I download Tuxboot following these instructions http://tuxboot.org/installation-screenshots.php but to no avail.
Any help please guys - I am using a Windows vista laptop.
You cannot partition the disk with Windows if it contains ext4 or btrfs partitions - Windows will not recognise them. You will need to stick an Ubuntu CD in your PC & boot from the CD. Then use gparted to fiddle with the partitions. Don't worry, this will not install anything on your PC.
