Post by ilovemyjoggler » Mon Aug 27, 2012 1:55 pm
spoyser wrote: In the settings you can auto-pick the LMS that it will connect to (does that bit work for you?)
Yes. Well, shows it but doesn't connect as I'm still on v0.8. Thanks for the help with the controls. I really don't fancy using a keyboard so I'll reboot into PNPIII and use squeezeplay when I want to listen to my music. I'll keep an eye on xsqueeze updates for improvements to touch controls though!
iLLiac4
Post by iLLiac4 » Wed Aug 29, 2012 5:09 am
Well I'm a little tight on time now, so I am not able to release any new versions. ATM I am working on some IT stuff with DC-s, Exchange and GPO integrations for the company I work for, which can sometimes be more boring than excited....
However I have made a list of changes and fixes that has to be implemented into the next release. I will probably wait for some response from XSqueeze developer (touch screen) so I can implement then the plugin with automatic resized background for it so that it will be less resource hungry and will be version independent. Will also try some stuff with performance optimization on XBMC for Juggler.
Also do not forget to report bugs, suggestions, donations,.... and all what comes with it. So stay tuned.
talkingbollox
Post by talkingbollox » Sat Sep 22, 2012 7:58 pm
When I power off/exit XBMC it leaves a fuzzy white band at the bottom of the screen. Is this normal?
Post by ilovemyjoggler » Sat Sep 22, 2012 8:20 pm
talkingbollox wrote:When I power off/exit XBMC it leaves a fuzzy white band at the bottom of the screen. Is this normal?
Me too. However it's been the most stable of os that i've tried even when i power off from there.
talkingbollox
Post by talkingbollox » Sat Sep 22, 2012 9:12 pm
ilovemyjoggler wrote: Me too. However it's been the most stable of os that i've tried even when i power off from there.
I was expecting the screen to be completely blank before I power off at the mains.
I moved from Jolicloud + XBMC. That was very stable, but obviously didn't boot straight into XBMC, but powered off perfectly.
Post by BuZz » Sat Sep 22, 2012 11:46 pm
just a comment regarding rebooting - emgd 1.10 was much more stable in many respects from newer releases. xorg crashes on exit and corrupts the framebuffer in newer releases. intel's support for this hardware has been massive crap :/ current xubuntu/jolicloud etc from me often crashes on reboot :(
iLLiac4
Post by iLLiac4 » Sun Sep 23, 2012 5:34 am
Yes reboot always seem to leave white line but it is not a problem since it reboots normally. Otherwise the next version will have also shutdown which works (if you want to power off the device).
Post by ilovemyjoggler » Sun Sep 23, 2012 6:32 am
BuZz wrote:just a comment regarding rebooting - emgd 1.10 was much more stable in many respects from newer releases. xorg crashes on exit and corrupts the framebuffer in newer releases. intel's support for this hardware has been massive crap :/ current xubuntu/jolicloud etc from me often crashes on reboot :(
BuZz, does this explain why my mint usb kept failing (every few days) or is it something else? I only use this xbmc os now as it's the only one i've tried that i've not had to reimage at all...
ILliac4, i'm really loving the speed and stability of this. Thanks so much! I know you're busy but is there any news on xsqueeze/squeezeplay? Not hassling... just curious. :D
iLLiac4
Post by iLLiac4 » Sun Sep 23, 2012 9:45 am
In few days you will probably get new version with touch support.
Hitcher
Post by Hitcher » Wed Sep 26, 2012 6:20 pm
I can't get SMB shares working. NFS shares work fine but whenever I try entering a media folder XBMC just freezes up.
talkingbollox
Post by talkingbollox » Sun Sep 30, 2012 5:03 pm
Has anyone got 1channel working? I'm getting an script error on version 0.1.5.0. Thanks
Post by BuZz » Sun Sep 30, 2012 5:11 pm
Hitcher, I cant help with smb shares on this, but they certainly work on xubuntu with xbmc on the joggler, so I'm unsure why they don't workm but you could test with that as a comparison.
Post by ilovemyjoggler » Sun Sep 30, 2012 5:32 pm
talkingbollox wrote:Has anyone got 1channel working? I'm getting an script error on version 0.1.5.0. Thanks
Just checked - it's working on mine. I'm still on v 0.8.
kappa__2
Post by kappa__2 » Mon Oct 01, 2012 5:28 pm
Can you build the pvr fork of xbmc instead?
I've been waiting for that build to pop up for ages... :roll:
Post by ilovemyjoggler » Mon Oct 01, 2012 5:54 pm
Post by BuZz » Mon Oct 01, 2012 5:57 pm
ilovemyjoggler - see http://wiki.xbmc.org/index.php?title=PVR
If people are interested in testing upcoming frodo releases, I could probably do a joggler build on a new ppa for testing.
kappa__2
Post by kappa__2 » Mon Oct 01, 2012 9:00 pm
Great!
Two interested: Me and myself. :D
Post by ilovemyjoggler » Mon Oct 01, 2012 9:54 pm
BuZz wrote:If people are interested in testing upcoming frodo releases, I could probably do a joggler build on a new ppa for testing.
Not sure what this is but I'm up for anything joggler tv related. Unless it's too complicated!
Hitcher
Post by Hitcher » Thu Oct 04, 2012 4:39 pm
What audio output device should I be using because I can't any sound from mine?
Post by BuZz » Thu Oct 04, 2012 4:49 pm
Hitcher - using standard analogue audio from joggler or via soundcard ? Audio should work out of the box if so, with 2.0, analogue and "default" audio device. Nice to see you over here btw ;-)
