Hi, i have an IP camera (tenvis jpt3815w) id like to know if there is any apps/software out there to use my IP camera as a "baby monitor" possibly with a squelch feature?
Anyone got cctv running on the stock OS?
Camera app for STOCK OS?
Re: Camera app for STOCK OS?
I have Zoneminder set up and tried the browser and it works fine. That said I had a few server side flash applications which worked just fine with the 800Mhz Chumby. You might also be able to install VLC on the stock OS. It works well in linux.
