ilovemyjoggler wrote:I have acquired another joggler and I want to install PNPIII on it. It has already been tinkered with as it has squeezeplay but no Iplayer (which is a must). Anyhoo, I still have my reflasher, openpeak update and pnpIII sticks and am guessing I need to either reflash or update first in order to get pnpIII on there?
Yeah, either use roobarb's reflasher or the openpeak one and start again.
Thanks offbeatdave!
I must admit, I've grown to like the Openpeak version as you get two more icons on the home page and one more on subsequent pages! Some of the older blue app buttons look a little out of place though!
IanL
Post by IanL »
Hi, sorry for this basic question but once this has installed to the Joggler, can the USB stick be removed or does it have to stay in like for the Android OS's etc.?
If it can be removed, can the joggler be rebooted without loosing this enhancement.
Thanks,
Ian
IanL wrote:...once this has installed to the Joggler, can the USB stick be removed or does it have to stay in like for the Android OS's etc.?
If it can be removed, can the joggler be rebooted without loosing this enhancement?
Once installed, the stick can be removed. It just adds to the original OS so it (and any app settings) survive rebooting!
IanL
Post by IanL »
Many thanks, I will give it a try. Thankyou in advance for all the hard work that I am sure has gone into this everyone.
ttherapo
Post by ttherapo »
Installed pnpiii last night,great addons to joggler.Last night everything was working great but today I get no sound(lounge,squeezebox,youtube etc).Any suggestions?
Mx560
Post by Mx560 »
I've been using android on my joggler for a while now but yesterday I decided to upgrade to PnP3 ,no problems with it at all ,
but I'm having trouble trying to create a samba share , I want my joggler to see my music collection on my Windows7 PC,
not really to sure what I'm doing but I've tried a load of commands from the forum (substituting my own details)
but just cant get it to work ,
when I go to the settings page of Logitech Media Server , go to media folders and browse I just cant get my PC to show up , thinking I'm doing something very wrong
Is Samba already installed or do I have to install it myself ?
ttherapo wrote:Installed pnpiii last night,great addons to joggler.Last night everything was working great but today I get no sound(lounge,squeezebox,youtube etc).Any suggestions?
Not sure to be honest. Reboot?
Mx560
Post by Mx560 »
Still trying to mount my PC , do I have to add the mount to fstab as well ?
if so how do I do that ?
Mx560
Post by Mx560 »
Why is so difficult to set up a share with this , I've got 3 other devices with shares that work well , hell I've even got it on my phone,
but just cannot get it to work , I've been at this for ages now
I'm assuming that with PnP3 installed it be some variation of
/bin/mount -t cifs //10.10.10.10\\music /media/YOURMOUNTPOINT -o user=auser,password=apass,iocharset=utf8
Mx560
Post by Mx560 »
Ok so heres what I'm trying
mount -t cifs //192.168.1.4/Mp3 /mnt/g -o user=xxx,password=xxxxxx
I'm trying to mount my Mp3 folder on my g drive, could someone show me where I'm going wrong,
I'm getting no such file or directory
bobbydee48
Post by bobbydee48 »
Sorry I am a bit of a newbie with PNP. I have the openpeak update and have downloaded pnp 111. How do I write this to a usb. Do I use Windisk32 .
Can some one give me an idiots guide to just using it from Usb stick as I cannot seem to Telnet with windows Xp.
Any help much appreciated. I am using Linux Mint But this looks much better.
bobbydee48 wrote:Sorry I am a bit of a newbie with PNP. I have the openpeak update and have downloaded pnp 111. How do I write this to a usb. Do I use Windisk32 .
Just unzip the downloaded PnP III file to a USB stick. It'll have 2 or 3 directories and a handful of files. If you have Windows XP, you should just be able to go to Start->Run and type in telnet to open telnet. With the USB stick in the Joggler type open xxx.xxx.x.x (replacing x with the Joggler's IP address from Settings->Network on the Joggler). You cannot install PnP III on an OpenPeak update without Telnet!
Mx560
Post by Mx560 »
Well I never did manage to set up a cifs share ,
but downloaded and installed the latest LMS on my PC and it works just fine
Mx560 wrote:Well I never did manage to set up a cifs share ,
Have you looked at the thread at http://www.jogglerwiki.com/forum/viewto ... 2&start=20
and the post at http://www.jogglerwiki.com/forum/viewto ... =20#p10481
The later PnP III builds reverted back to the older busybox as the newer version broke networking a bit.
Mx560
Post by Mx560 »
Sure did , spent 3 days searching through the forums and googling for answers but for some reason no matter what I tried , just wouldnt happen ,
have to stress here though that I'm kinda a newbie
bobbydee48
Thanks for the advice offbeatdave. I will try and use Telnet and let you know how I get on.
Hello, I have the most current version of squeezeplay (on PnPIII) ....every now and then it tells me it's playing a track but there is no sound and no movement or song length on the timebar (or whatever that bar is called). Last night 5 reboots to get it to work - the joggler had been off earlier in the day so this wasn't something that happened whilst it was idle. Roobarb suggested i post here - any ideas as to what might be causing a problem?
bobbydee48
I am writing the reflash to usb stick using windisk32 When I try to open the usb it says stick is formatted. Should I be using another programme to write to the stick.
I then need to transfer the flash script, I am getting there but slowly.
