Hmm. I've just re-read the installation instructions in post 1 and decided that a couple of them needed to be made clearer. The Webserver is only available once reflashing is complete.Mcja9543 wrote:So I went to my web browsers (plural as tried them all) put in the IP address of my Joggler network and nothing found.
Tried the software from a hard drive use connection...nothing happened. What do I do to install April 2015 PnpIII ?
Instructions
NOTE: ALL SETTINGS WILL BE LOST.
It goes without saying that I take no responsibility if anything untoward should happen to your Joggler, although fortunately there are plenty of us here who are willing to help in the unlikely event that it does!
Stage 1 - make sure the Joggler is running the latest operating system.
Use Roobarb's re-worked OpenPeak image and reflash tool. Find it at Roobarb's birdslikewires site. The advantage of this is a cleaner image and the ability to install automatically without telnet.
Stage 2 - Install PnP III
Works with Jogglers reflashed with Roobarb's cleaner post-update OpenPeak OS v30300 (recommended) or Jogglers running the original o2 OS
1) Make sure your Joggler is 'clean'.
Use the reflasher from birdslikewires.co.uk to achieve this with your preferred version.
2) Unzip the downloaded archive and copy all the files to the root a FAT32 formatted USB stick .
Make sure any hidden files are copied.
Make sure there is no 'remove_for_new_install' file on the root USB stick
3) With the Joggler turned off, plug the USB stick into your clean Joggler, switch it on and leave it to do its thing!
This method does not require network or internet connection.
This can take 10-20 minutes depending on the USB stick.
It may 'reboot' a few times but will stay on the 'OpenPeak' or 'o2' boot screen, looking for all the world as if nothing is happening. Flashing USB sticks however tell otherwise.
4) The Joggler will eventually reboot into the OS with all the new apps and icons
5) You will need to remove the 'remove_for_new_install' file from the USB stick after use to use it again.
Once installation is complete:
SSH, SCP, Telnet enabled(username: joggler password: joggler)
Simple Webserver available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS>
Logitech Media Server (LMS) available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS:9000>
NOTE: IF YOUR JOGGLER IS TEMPERAMENTAL AND DOESN'T RESPOND WELL (I.E. FAILS) IF REBOOTED TOO OFTEN, USE THE 'MANUAL' METHOD INVOLVING TELNET BELOW:
1) Make sure your Joggler is clean (See roobarb's reflashing instructions - linked above).
2) Unzip the downloaded archive and copy all the files to a formatted USB stick .
3) Make sure your joggler is connected to your network.
Although internet access is not required to install PnP III,
you need network access to be able to Telnet in!
4) Plug the PnP III USB stick into an updated Joggler (with it powered on).
5) Telnet into the Joggler via a computer. The username is root and there is no password.
(open <your Joggler's IP address>)
4) Type in:
cd /mnt/files <press Enter>
./pnp3op.sh <press Enter>
6) Loads of stuff will scroll up the Telnet window whilst the mods are installed.
7) The Joggler should eventually reboot into the OS with all the new apps and icons
8) If it is present, remove the 'remove_for_new_install' file from the USB stick after use.
SSH, SCP (username: joggler password: joggler) will be enabled in addition to Telnet (username: root)
Logitech Media Server available via a browser at <YOUR_JOGGLER'S_IP_ADDRESS:9000>
