Gave up with trying to load pnp3 with usb on old o2 image, Flashed to openpeak and can now telnet.comes up with cant cd to /mnt/files
Beginning to think I must be doing something wrong unpacking pnp 3 to usb stick original o2 does not update with pnp3 on usb and when I try to telnet it does not see the usb either, Tried several usb sticks. Anyone any more ideas.
@bobbydee48: I got the same message as you when it didn't like my usb. Tried another and it worked. Did you try unzipping the PnPIII to your desktop first and then copying to a clean usb?
as asked earlier, can you list what is in the root of the usb stick so we can see if anything is missing.
Files, Squeezefavorites,.sum Changelog opupdt.run readme instructions radiostations catalog boothacks opupdt ( winrar) pnp_install.sh version
This is all that is showing when unzipped to usb.
(ilovemyjoggler) tried several usb sticks and unzipped to desktop the copied to a freshly formatted usb fat 32.
Hope this helps solve my problem.
Have you left the usb in for long enough before trying to telnet in and access it? I like to pop it in, leave it thirty seconds and then telnet in. I'll check the integrity of the upload tomorrow. Have you tried redownloading though?bobbydee48 wrote:Gave up with trying to load pnp3 with usb on old o2 image, Flashed to openpeak and can now telnet.comes up with cant cd to /mnt/files
That sounds right from memory.bobbydee48 wrote:Files, Squeezefavorites,.sum Changelog opupdt.run readme instructions radiostations catalog boothacks opupdt ( winrar) pnp_install.sh version
also, what brand and size usb sticks have you used so far?
I'm struggling trying to get a USB hard disk to auto-mount.
I presume auto-mounting works, since USB memory sticks seem to do it. But how do you get a disk drive to auto-mount?
I've tried putting an entry in fstab, and then mounting the drive manually, - that works but it's a manual process which needs to be repeated if you unplug/plug.
I've tried adding a mount script into /etc/init.d/boot.d to mount the disk at boot time. Again, it works at boot time but not if you unplug/plug.
Googling for it tells me I should be using udev rules. But the udev system doesn't seem to work for this build of Linux.
Any ideas?
Any ideas?
Tried 2gb 2x 4gb 3x 8gb usb sticks. No luck. Found an old 512mb stick and tried it before I gave up. It is working spot on. Do not know why all the rest will not work,
Thanks to everyone for being patient with me. This joggler is great. Now to update my other two for the boys.
Whoop whoop!bobbydee48 wrote:Tried 2gb 2x 4gb 3x 8gb usb sticks. No luck. Found an old 512mb stick and tried it before I gave up. It is working spot on. Do not know why all the rest will not work,
It's amazing how some Jogglers seem so picky with USB sticks. I've never had a problem with anything I've stuck in any of mine but your struggle is not an unfamiliar one among Joggler users. Anyway, glad it's all working now and you can enjoy the unleashed potential of the Joggler!
OMG!bobbydee48 wrote:Tried 2gb 2x 4gb 3x 8gb usb sticks. No luck.
@offbeatdave: Still a bit chuffed... I was kinda right - I got the same error message when it didn't like my usb too!offbeatdave wrote:Whoop whoop!
Hi, I cant seem to get this to install. any help would be grateful
What stage are you getting problems at?Nick wrote:Hi, I cant seem to get this to install. any help would be grateful
offbeatdave,
Wondering how I would add widgets to your PnP III such that I could play custom video feeds (security cams) using jwplayer?
So far I have put the media player in the appshop directory and modified the applications.xml file such that it includes the media player.
Hi Pete. Is the player a swf app?pete_c wrote:offbeatdave,
Yes it is offbeatdave. I was able to get the icons on the Joggler. The examples all show though an accompanying java script then calling it from html.
If it doesn't run itself from the swf, then you could try launching it through the SWF Manager. Chess, Angry Birds, Crush the Castle etc all do this so if you have a probe in their directories, you'll see the way in which I invoke the SWF manager to run swf apps.pete_c wrote:Yes it is offbeatdave. I was able to get the icons on the Joggler. The examples all show though an accompanying java script then calling it from html.
Basically they're launched through a cgi script containing something like the following (for the chess app for example)
#!/bin/sh
/media/squeezingtarkan/app/flashapp.sh http://localhost:80/starter/chess/chess.swf
JW Player
OK, I've managed to get this to launch. It didn't do it itself so I had to do the stuff mentioned above (call it from a cgi script). The app loads up, there is a bottom toolbar with play, menu etc. but nothing appears to be selectable. Is this because something needs adding to the js file?pete_c wrote:Yes it is offbeatdave. I was able to get the icons on the Joggler. The examples all show though an accompanying java script then calling it from html.
I've even got so far as to create a little script to add it to the Joggler...
wget http://dl.dropbox.com/u/77534245/installjwplayer.sh
sh ./installjwplayer.sh
rm -r installjwplayer.sh
That's great offbeatdave! I built the 97X97 icon PNG file for the widget view. Here is one html example for loading a specific video stream / file.
My goal is to stream HD rtsp. I guess its supposed to be able to do this.
<script type="text/javascript" src="/jwplayer/jwplayer.js"></script>
<div id="container">Loading the player ...</div>
<script type="text/javascript">
jwplayer("container").setup({
flashplayer: "/jwplayer/player.swf",
file: "/uploads/video.mp4",
height: 270,
width: 480
</script>
Just a quick heads-up to say I've updated the pics in the opening post to show the current version's screens.
