can I buy this?
cszhy
can I buy this?
Post by cszhy »
Hi there:
I found a joggler selling online which stuck on the O2 logo when starting
not sure whether I can use the reflash tool to fix it.
any ideas?
thanks
Re: can I buy this?
Yes.
O2 Joggler will boot first from a USB stick. The inside eMMC could be in a corrupt state. That said try writing first to the inside eMMC. It might boot.
If not then you can use an external USB stick for the OS.
cszhy
Re: can I buy this?
Post by cszhy »
pete wrote: Tue Aug 17, 2021 12:48 pm Yes.
thanks Pete!
