Docker on Ubuntu 14.04
abzee
Post by abzee »
My joggler has been resting ..so I want to revive it ...If I can install Home assistant and be able to control some smart devices.
Is there a setup guide to install.. I believe I need to install a specific version of Ubuntu that works and on top add HA.
Any pointers much appreciated.
abzee
Re: Joggler as Home Assistant Host
Post by abzee »
got this link : https://jwills.co.uk/projects/joggler-xubuntu/download/
Hopefully it should sort out my needs
abzee
Post by abzee »
Install Ubuntu as per above instructions.
having issues installing Docker on Ubuntu 14.04
W: Failed to fetch https://download.docker.com/linux/ubunt ... /InRelease Unable to find expected entry 'stable/binary-arm64/Packages' in Release file (Wrong sources.list entry or malformed file)
is there anything I need to do special
abzee
Post by abzee »
abzee wrote: Tue May 11, 2021 11:13 am Hi
abzee wrote: Thu May 13, 2021 9:48 amW: Failed to fetch https://download.docker.com/linux/ubunt ... /InRelease Unable to find expected entry 'stable/binary-arm64/Packages' in Release file (Wrong sources.list entry or malformed file)
Looks like it's trying to fetch ARM 64-bit binaries on an x86 32-bit device. I take it you added the repo? You'll need to only add lines for 32-bit x86 (not 64-bit x64).
The Ubuntu Trusty images also date back to 2017; they may be fine, but I have no idea. You can download Ubuntu Bionic from the link in my sig if you want.
