joggy
Posts: 21 Joined: Tue Jan 01, 2019 11:07 pm
Post
by joggy » Wed Apr 21, 2021 1:24 pm
I am trying to run 2 jogglers with the birdslikewires Ubuntu Bionic (Kernel 3.16) for OpenFrame image but they keep getting the same IP4 address via DHCP. I checked and they have a different MAC address and I even changed the hostname in /etc/hostname but they still get the same IP. Anyone knows how this should be fixed? thx!
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.64 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fd95:c79b:3c7d::99f prefixlen 128 scopeid 0x0<global>
inet6 fe80::a0:86ff:fe2d:b48e prefixlen 64 scopeid 0x20<link>
inet6 fd95:c79b:3c7d:0:a0:86ff:fe2d:b48e prefixlen 64 scopeid 0x0<global>
ether 02:a0:86:2d:b4:8e txqueuelen 1000 (Ethernet)
RX packets 167 bytes 25687 (25.6 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 129 bytes 17549 (17.5 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
inet6 fe80::e:8eff:fe25:a73 prefixlen 64 scopeid 0x20<link>
inet6 fd95:c79b:3c7d:0:e:8eff:fe25:a73 prefixlen 64 scopeid 0x0<global>
ether 02:0e:8e:25:0a:73 txqueuelen 1000 (Ethernet)
RX packets 256 bytes 97827 (97.8 KB)
TX packets 216 bytes 30867 (30.8 KB)
Posts: 2950 Joined: Mon Aug 01, 2011 6:33 am
Post
by pete » Thu Apr 22, 2021 2:45 pm
You can put a mac address / firmware on the Realtek NIC on the Joggler if you want.
1 - you basically write an image to any USB stick to do this.
2 - replace the EFI bios with a Seabios
3 - write the mac address to the Realtek chip via command line once you boot in to DOS
4 - reboot and hit the F12 key and reload the Joggler EFI bios
5 - you should be good to go then.
Writing a MAC address to a Joggler NIC
viewtopic.php?f=4&t=2301&start=20
joggy
Post
by joggy » Wed Jun 02, 2021 10:49 am
I changed the MAC via bios as you described, I changed the MAC in /boot/network.yaml and I changed the hostname via hostnamectl but they still get the same IP address??!??
Post
by pete » Wed Jun 09, 2021 4:47 am
Guessing you made each MAC address unique to each Joggler?
Install ethtool
sudo apt install ethtool
sudo ip link show
Each joggler should have a unique MAC address.
Then do:
sudo ethtool mac_address
This will show the hardware nic specs.
Both Jogglers hardware mac addresses should be unique.
Try this also:
lshw -class network
This will show the MAC address after serial:
The two jogglers should have unique mac addresses.
do a copy and print of what you see and post it here please.
Post
by pete » Wed Jun 09, 2021 5:19 am
Apologies I did not read your previous post.
I am assuming that you assigned a unique mac address to each Joggler eh?
