*Download the ICS Alpha 2 and the Easy to Use Internal package from http://www.mporting.com/download/
*Unzipped the ICS Alpha 2 to a Fat32 USB stick and then copied the files from the Internal package over the top.
*Booted into Ubuntu on the Joggler via a hub and used GParted to format the internal flash to fat32
*Inserted the android stick into the hub
*In terminal, copied across the files from the Android USB stick using
sudo mount /dev/mmcblk0p1 /mnt
sudo cp -r /media/NAMEOFUSBSTICK/* /mnt
sudo umount /mnt
This is all working well at the moment (well, 1 hour in anyway!) BBC News app from Google Play is looking good, as is the Sky Sports News app.
