Windows Help Required, Please.
cbredfred
Post by cbredfred » Sun Mar 18, 2012 8:41 pm
I'm having a hard time getting the "3CX Gateway for Skype" to run on my Joggler and was wondering if anyone that is running ANY of the Joggler Windows builds could try to install it on their build and then let me know which build they are using and if the "3CX Gateway Monitor" program will run?
The 3CX Gateway for Skype is a small add on to the main 3CX phone system software and it creates a link between it and Skype so that calls can be made and received using Skype. I don't think that the main 3CX phone system or Skype need to be installed to see if you can get further than I am.
The software can be downloaded from here:
http://www.3cx.com/downloads/3CXGatewayforSkype2.msi
Please install the software. Then when you click "Finish" it should open the 3CX Gateway Monitor program....
This is where I get the following error:
"Gateway configuration program is already in use by another computer user. please try again later!"
The 3CX Gateway Monitor program should be in your Programs list on the Start button if you could try it a couple of times that would be great.
Thank you for the help.
P.S. I'm on Mevi's latest build, if you are too, then it would still be useful to me if you could test it for me.
