O2: Updating O2 Joggler on 30th April
Re: O2: Updating O2 Joggler on 30th April
No update yet for me....
Great - just done this, and I've also done this (scroll down to the bit about disabling updates):roobarb! wrote:In case anybody else is less than enamoured with the update (on balance, I think my preference is for the O2 version), if you have not already been updated you could try using the Update Control tool (click the 'various tools' link in my sig). It should, I think, prevent the new update from being applied.
http://webdiary.com/2010/11/05/squeezeb ... -a-budget/
They won't get me I tell you!
Actually, my Joggler didn't offer me the update after nearly two days of waiting before I did any of this...
Glenn
This is kind of very similiar to what happened to the Logitech Revue box once discontinued. Logitech though went one more step "beyond"; first upping the OS to ICS, removed many features from it; then locked it up such that you couldn't tweak it anymore.
O2 though left the door open such that you could still keep using old firmware or continue to modify newest based no frills FW.
Well, neither of my Jogglers got updated automatically ... so I used the supplied image to 'update' one ... and so far am pretty unimpressed.
As others have said, it removes most of what is useful and adds stuff I don't want or need.
I plan on adding the /etc/hosts patch to prevent my main joggler being updated.
I've lost track ... is there any way I can revert to the stock S/W?
Thanks a lot
J^n
Thanks a lot
J^n
How do I prevent the update again?
Is there a date after which the O2 update will pass and I no longer have to worry about the forced update?
2 Jogglers plugged in hooked up to internet no updates so far
The updates haven't made it as far north as Scotland yet.
Thank goodness!dwl99 wrote:The updates haven't made it as far north as Scotland yet.
No update for me yet (Oxfordshire)
My reflash tool should still work fine to go back to O2 version from the OP one. It'll work forever if you hang on to the image file it downloads.jkn wrote:I've lost track ... is there any way I can revert to the stock S/W?
That's great, thanks, I'll give that a go for nowroobarb! wrote:My reflash tool should still work fine to go back to O2 version from the OP one. It'll work forever if you hang on to the image file it downloads.jkn wrote:I've lost track ... is there any way I can revert to the stock S/W?
J^n
Actually, I'm having second thoughts ... if i can ensure my 'Joggler #1' doesn't get updated, then I might use this as an opportunity to try Android on my newly-updated Joggler#2.jkn wrote:
Can someone give me an idea what the current position is re. overheating and throttling when running Android on a joggler? I see there is a command-line parameter to allow the CPU to get up to eg. 80. I originally planned to do a heatsink mod, but won't be able to get around to this for a while .. is this still necessary/a good idea? i'm wondering if recent improvements to Android have cut the consumption down sufficiently...
J^n
I think you'd be better off asking in one of the Android threads, so the right people get to see it.jkn wrote:Can someone give me an idea what the current position is re. overheating and throttling when running Android on a joggler?
The updates don't seem to have got to me yet, which may or may not be a good thing! However, I noticed that the clock no longer receives updates from t'internet. Is this a seperate issue or part of the update fiasco?
Android 2.2 has no temperature issues and does not require throttling.
Mine has not updated yet . Clock seems to be working, just a message from O2.
OK thanks. Probably a different issue then.Nicjwin wrote:Mine has not updated yet . Clock seems to be working, just a message from O2.
After reading the threads on here about the update it doesn't look like a great improvement. Shame its as complicated as it is to get Android to be the boot OS, that would be nice, but although the instructions are there they make no sense to me whatsoever! Guess that's what you get for being a Luddite.
Have you tried this method of installing Android http://www.jogglerwiki.com/forum/viewto ... ?f=2&t=318 ? It could hardly be any easier!
Sure - I wasn't planning to go any more off-topic ;-oroobarb! wrote:I think you'd be better off asking in one of the Android threads, so the right people get to see it.jkn wrote:Can someone give me an idea what the current position is re. overheating and throttling when running Android on a joggler?
Jon N
No update in Cheltenham yet - don't want it either i like my Joggler just the way it is at the mo!
