JazzMod:Source InDev 1 (coming soon)
Re: Mijuu-based JazzMod ICS v1.0 (Working Market! - RELEASED
BTW, custom bootscreen is nice jazz!
I'm happy, doods music streamer works! lol EDIT: it loads but no songs play :(
Am I being really stupid, but how do you do turn volume up and down?
EDIT 2: Never mind, forgot that android x86 has no flash llol
Think this build is still very much a work in progress ,it reminds me of the build before 1.2.3 ,
Doods music streamer works fine on that :-)
Here's to Mijuu's next build can't believe how much progress he's made on this one allredy ..
For anyone wanting a stableish build of android the fixed 1.2.3 is still the one to go for ..
Hapy Joggling
jazzmista
Post by jazzmista »
Quinten wrote:Working just fine over here, thanks!
1st boot took a bit longer than usual, but not that long tbh. Market did the thing where you had to press Wait, and then bounced into life. One thing I am missing so far is a 'reboot' button/widget, but I guess root is something we can't do yet?
Q.
doojit wrote:Many thanks works a treat
Phew - was getting worried then!
ICS is actually rooted, but the SuperUser binaries do not work on x86 (like most things it seems :-( ) You can still enter su commands into terminal though.
jazzmista
Post by jazzmista »
danfoshizzle wrote:No its worse, windows vista! :P
Think you'd be better off with Windows 3.1 :-P
danfoshizzle wrote:BTW, custom bootscreen is nice jazz!
Thanks!
doojit
Post by doojit »
Get a error -101 when try to download from market
jazzmista
Post by jazzmista »
doojit wrote:Get a error -101 when try to download from market
Apparently it will either go away or you can delete your Google Account from the device and then add it again -
http://androidforums.com/samsung-galaxy ... 101-a.html (same build of com.android.vending.apk as the Nexus)
doojit
Post by doojit »
Thanks I'll give it a go cheers
I used Vista for a weekend when my laptop was new. Yuk. Did the service pack(s) or windows updates make it any better? Y U No W7?
I've downloaded this ICS,but I'm away from home tonight. I really liked the last one Mijuu posted and i kept it as a bedside clock for a few days. I also saw his port of meego which I'd not seen before. I'll have a go on that too.... when I get a minute as UK Netflix (and US on a VPN on the same account!!!) is taking up all my time now. Is there a chance that the ICS animated backgrounds will work at some point on the Joggler?
doojit
Post by doojit »
Still no joy with the 101 error just a little niggle great work on what you've done runs great
doojit
Post by doojit »
Sorted many thanks
teddington.whambar
Post by teddington.whambar »
Hey Jazzmeista,
Great release. Feels and looks as good as the 1.2.3 release.
Do you know how to go about enabling the NIC interface? and also a working version of beebplayer?
I use the beebplayer to listen to the radio in the morning and the NIC interface prevents the streaming from cutting out.
Thanks for your help
Ted
jazzmista
Post by jazzmista »
teddington.whambar wrote:Hey Jazzmeista,
Ted
Thanks! It is Mijuu who should get the credit though - I just added a few tweaks and compiled it ;)
Basically, any app that isn't compiled for Android x86 (which is a lot) won't work on this ICS build. Did beebplayer work on 1.2.3? As far I as I am aware, NIC doesn't work on Android-x86 ICS, and therefore will not work on the Joggler. I'll see what I can do though!
jazzmista
Post by jazzmista »
doojit wrote:Sorted many thanks
Glad to hear it :-)
I'm currently looking at trying to get SuperUser to work - it runs but then refuses to download the binaries. Will try and see if installing to /system/app/ and manually installing the binaries works!
Quinten
Post by Quinten »
It survived the 1st night, although one thing does bother me... the screen dims, and although i can set the timeout, it will only go to 30 minutes... is there any way of getting rid of the dimming at all?
jazzmista
Post by jazzmista »
Quinten wrote:It survived the 1st night, although one thing does bother me... the screen dims, and although i can set the timeout, it will only go to 30 minutes... is there any way of getting rid of the dimming at all?
I'll have a look for you :-)
jazzmista
Post by jazzmista »
Hi all,
I've had my Dropbox account suspended for 3 days because I have used up too much bandwidth on my outgoing links (aka JazzMod :-) ) so the download is currently down. Apologies - I didn't realise they did that! I will get another download link up in the next few days. In the meantime, can one of you lucky ones who managed to download it provide a mirror upload for me?
Jamie
spez.uk
Post by spez.uk »
Great release thanks for putting it all together. :mrgreen:
Some apps that i have working on it at the mo...
ES File Explorer - for navigating to network drive.
AirDroid - Easier to transfer files and install apps.
Button Savior - really needed app as with quite a few apps like airdroid you loose the menu UI at the bottom.
Just trying to get pWall to work - nice little wallpaper slideshow app
edit: gave up on pWall, using Multipicture live.
hawsey wrote:Think this build is still very much a work in progress ,it reminds me of the build before 1.2.3 ,
Hapy Joggling
Ooops I sound a bit ungreatfull here Jazz sorry didn't mean to be .
What I meant to say was that this build is ICS Mijuu work in progress for testing purposes , hopefully there will be another one along sometime soon ready for Jazz or another clever bod to work his magic on :D
I think I have a good copy of this image , where is the best place to upload too ? Have only used dropbox before and don't want to bork that !!
Will try tomorrow unless someone else manages first
Gary
Quinten
Re: Mijuu-based JazzMod ICS v1.0 (Working Market! - LINK DOW
Post by Quinten »
Here's my (temporary if I may add) mirror (on Virgin 50mbs): http://awooga.nl/stuff/joggler/jazzmod01.7z
