JazzMod:Source InDev 1 (coming soon)
jazzmista
Post by jazzmista »
Hello and welcome to JazzMod:Source! This a source build of ICS for Joggler, based on Mijuu's excellent work. At the moment it has no extra features (due to the issues I have been having with my build environment), but I think I've cracked OpenPeak 7E WiFi support and I will add more community-requested features soon.
Changelog:
InDev 1
  • Built from source
    Timezone Fix (incorporating Google Play Store fix)
    English Default Language
V1.0
  • Working GoogleServicesFramework.apk and com.android.vending.apk (market)
    Default language is English
    Wiped Data partition
    OI File Manager installed (same as used on CyanogenMod)
    Custom Boot Animation
A fair number of apps will not display in the market due to them not being compiled for X86 - nothing I can do about it until the developers enable support for X86, which is growing! This will be rectified with InDev 2, which will enable ARM Emulation support.
Download:
http://joggler.exotica.org.uk/img/android/jazzmod01.7z
(v1.0 ONLY - new download links coming after testing)
537mb expands to ~3.8gb, and it will fit on a 4GB USB stick :-)
EDIT: Tutorial (which I completely forgot about!)
1) Download using link above
2) Extract zip file
3) On Windows, use Win32 Image Writer (https://launchpad.net/win32-image-writer) to write to your USB drive
4) Plug in and go!
Thanks to Mijuu over at Mporting: http://www.mporting.com
Enjoy!
Quinten
Re: Mijuu-based JazzMod ICS v1.0 (Working Market! - RELEASED
Post by Quinten »
Downloading it now :D
james
Post by james »
sorry for my ignorance... a long time since i download android for joggler and the last attempt didn't get much working... i;ve only browsed the android threads since then
do you have a list of apps that do work?
i'm interested in
tunein
decent browser for reading
iplayer
aljazeera
economist
angry birds or other fun touch screen games?
cheers
james
jazzmista
Post by jazzmista »
james wrote:sorry for my ignorance... a long time since i download android for joggler and the last attempt didn't get much working... i;ve only browsed the android threads since then
i'm interested in
tunein
iplayer
aljazeera
economist
cheers
james
I'll check those out for you and report back :-)
Kampfwurst
Post by Kampfwurst »
how can I install the JazzMod?? Is there a tutorial??
jazzmista
Post by jazzmista »
Kampfwurst wrote:how can I install the JazzMod?? Is there a tutorial??
I completely forgot about the tutorial! I've added one to the main post :-)
Kampfwurst
thanks.
Is it normal that it takes long to start? I put the USB Stick into the Joggler. It starts Android. Now it stoppt at a blue Screen with the flashing JazzMod for Joggler writting. The USB Stick LED stopped flashing.
james
Post by james »
netflix would be nice too!!!
doesn't work on ubuntu due to silverlight.... so that would probably convince me to switch!
Kampfwurst
on my Joggler it isnt working. :o after 1 minute it stops. I only see the blue screen with ICS for Joggler and a smal black box flashing.
tmohammad
Post by tmohammad »
Thanks for this...
currently I use ubuntu. This allows me to use a wireless mouse & keyboard using a usb dongle.
Will I be able to use a wireless mouse & keyboard with this android ICS image?
jazzmista
Post by jazzmista »
Kampfwurst wrote:on my Joggler it isnt working. :o after 1 minute it stops. I only see the blue screen with ICS for Joggler and a smal black box flashing.
Sorry about this!
Is the ICS For Joggler text still appearing and disappearing? If it is, then it is still booting - it can take around 10-15 minutes for first boot sometimes :-(
If not, try reflashing your USB stick - it happened once on a Mijuu build for me and it worked fine after a reflash!
jazzmista
Post by jazzmista »
tmohammad wrote:Thanks for this...
I'm not sure... The best way to find out is to try it :-)
jazzmista
Post by jazzmista »
james wrote:netflix would be nice too!!!
Currently testing your apps...
Angry Birds - no
TuneIn Radio - boots, can view streams but force closes
Economist - sort of but messes up status bar (with buttons) big style
Will update this post as I do more tests
james
Post by james »
thanks jazzmista! exciting times! i have downloaded it but not installed yet...
miccheck1516
Post by miccheck1516 »
great thanks a bunch will have a play later in the week
Quinten
Post by Quinten »
Working just fine over here, thanks!
1st boot took a bit longer than usual, but not that long tbh. Market did the thing where you had to press Wait, and then bounced into life. One thing I am missing so far is a 'reboot' button/widget, but I guess root is something we can't do yet?
Q.
doojit
Post by doojit »
Many thanks works a treat
Cheers jazzy! for some reason unraring is taking longer than the download did :P
damn you pc
Time you replaced your Windows 3.1 machine :-)
No its worse, windows vista! :P
