EMGD Xorg and Linux.
-=xXx=-
Post by -=xXx=- » Sat Mar 10, 2018 6:49 pm
Hi...
I have small question I installed emgd driver also xorg 1.9.5 I see tat it loads from xorg.log but in glxinfo I still see Software acceleration.
Maybe someone has a clue what can be wrong ,I'm attaching xorg logs.
X.Org X Server 1.9.5
Release Date: 2011-03-17
[   916.984] X Protocol Version 11, Revision 0
[   916.984] Build Operating System: Linux 4.4.0-101-generic i686
[   916.985] Current Operating System: Linux openframe 3.2.53jog1 #1 SMP Tue Dec 10 09:21:21 GMT 2013 i686
[   916.985] Kernel command line: acpi=force reboot=acpi intel_idle.max_cstate=2 thermal.psv=80 irqpoll BOOT_IMAGE=/vmlinuz-3.2.53jog1 root=LABEL=t3-root ro quiet
[   916.986] Build Date: 10 December 2017  12:09:03AM
[   916.986]
[   916.989] Current version of pixman: 0.30.2
[   916.992]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[   916.997] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   917.006] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan  1 00:16:11 2005
[   917.014] (==) Using config file: "/etc/X11/xorg.conf"
[   917.017] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   917.026] (==) No Layout section.  Using the first Screen section.
[   917.026] (==) No screen section available. Using defaults.
[   917.026] (**) |-->Screen "Default Screen Section" (0)
[   917.026] (**) |   |-->Monitor "<default monitor>"
[   917.026] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[   917.026] (**) |   |-->Device "Intel EMGD"
[   917.026] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[   917.027] (==) Automatically adding devices
[   917.027] (==) Automatically enabling devices
[   917.036] (WW) The directory "/usr/share/fonts/X11/TTF/" does not exist.
[   917.036]    Entry deleted from font path.
[   917.036] (WW) The directory "/usr/share/fonts/X11/OTF/" does not exist.
[   917.036] (WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
[   917.036] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   917.036] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   917.036] (==) FontPath set to:
        /usr/share/fonts/X11/misc/
[   917.036] (==) ModulePath set to "/usr/lib/xorg/modules"
[   917.036] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[   917.036] (II) Loader magic: 0x8220e40
[   917.036] (II) Module ABI versions:
[   917.036]    X.Org ANSI C Emulation: 0.4
[   917.036]    X.Org Video Driver: 8.0
[   917.036]    X.Org XInput driver : 11.0
[   917.036]    X.Org Server Extension : 4.0
[   917.038] (--) PCI:*(0:0:2:0) 8086:8108:8086:8119 rev 7, Mem @ 0xd0100000/524288, 0xc0000000/268435456, 0xd0180000/262144, I/O @ 0x0000f070/8
[   917.038] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   917.038] (II) LoadModule: "extmod"
[   917.053] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[   917.059] (II) Module extmod: vendor="X.Org Foundation"
[   917.059]    compiled for 1.9.5, module version = 1.0.0
[   917.059]    Module class: X.Org Server Extension
[   917.059]    ABI class: X.Org Server Extension, version 4.0
[   917.059] (II) Loading extension MIT-SCREEN-SAVER
[   917.059] (II) Loading extension XFree86-VidModeExtension
[   917.059] (II) Loading extension XFree86-DGA
[   917.060] (II) Loading extension DPMS
[   917.060] (II) Loading extension XVideo
[   917.060] (II) Loading extension XVideo-MotionCompensation
[   917.060] (II) Loading extension X-Resource
[   917.060] (II) LoadModule: "dbe"
[   917.060] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[   917.063] (II) Module dbe: vendor="X.Org Foundation"
[   917.063]    compiled for 1.9.5, module version = 1.0.0
[   917.063]    Module class: X.Org Server Extension
[   917.063]    ABI class: X.Org Server Extension, version 4.0
[   917.063] (II) Loading extension DOUBLE-BUFFER
[   917.063] (II) LoadModule: "glx"
[   917.063] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   917.071] (II) Module glx: vendor="X.Org Foundation"
[   917.080]    compiled for 1.9.5, module version = 1.0.0
[   917.080]    ABI class: X.Org Server Extension, version 4.0
[   917.080] (==) AIGLX enabled
[   917.080] (II) Loading extension GLX
[   917.083] (II) LoadModule: "record"
[   917.084] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[   917.087] (II) Module record: vendor="X.Org Foundation"
[   917.087]    compiled for 1.9.5, module version = 1.13.0
[   917.087]    Module class: X.Org Server Extension
[   917.087]    ABI class: X.Org Server Extension, version 4.0
[   917.087] (II) Loading extension RECORD
[   917.087] (II) LoadModule: "dri"
[   917.087] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[   917.096] (II) Module dri: vendor="X.Org Foundation"
[   917.096]    compiled for 1.9.5, module version = 1.0.0
[   917.096]    ABI class: X.Org Server Extension, version 4.0
[   917.096] (II) Loading extension XFree86-DRI
[   917.096] (II) LoadModule: "dri2"
[   917.096] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[   917.099] (II) Module dri2: vendor="X.Org Foundation"
[   917.099]    compiled for 1.9.5, module version = 1.2.0
[   917.099]    ABI class: X.Org Server Extension, version 4.0
[   917.099] (II) Loading extension DRI2
[   917.099] (II) LoadModule: "emgd"
[   917.099] (II) Loading /usr/lib/xorg/modules/drivers/emgd_drv.so
[   917.119] (II) Module emgd: vendor="Intel(R) Corporation"
[   917.119]    compiled for 1.9.0, module version = 1.18.3398
[   917.119]    Module class: X.Org Video Driver
[   917.119]    ABI class: X.Org Video Driver, version 8.0
[   917.120] (II) EMGD: Intel(R) Embedded Media and Graphics Driver version 1.18.3398 for:
        Intel US15W Class
[   917.120] (--) using VT number 7
[   917.128] (II) EMGD(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[   917.128] (==) EMGD(0): RGB weight 888
[   917.128] (==) EMGD(0): Default visual is TrueColor
[   917.128] drmOpenDevice: node name is /dev/dri/card0
[   917.128] drmOpenDevice: open result is 8, (OK)
[   917.128] drmOpenByBusid: Searching for BusID PCI:00:00:00
[   917.129] drmOpenDevice: open result is 8, (OK)
[   917.129] drmOpenByBusid: drmOpenMinor returns 8
[   917.129] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.129] drmOpenDevice: node name is /dev/dri/card1
[   917.133] drmOpenByBusid: drmOpenMinor returns -1
[   917.134] drmOpenDevice: node name is /dev/dri/card2
[   917.139] drmOpenByBusid: drmOpenMinor returns -1
[   917.139] drmOpenDevice: node name is /dev/dri/card3
[   917.144] drmOpenByBusid: drmOpenMinor returns -1
[   917.144] drmOpenDevice: node name is /dev/dri/card4
[   917.150] drmOpenByBusid: drmOpenMinor returns -1
[   917.150] drmOpenDevice: node name is /dev/dri/card5
[   917.155] drmOpenByBusid: drmOpenMinor returns -1
[   917.155] drmOpenDevice: node name is /dev/dri/card6
[   917.161] drmOpenByBusid: drmOpenMinor returns -1
[   917.161] drmOpenDevice: node name is /dev/dri/card7
[   917.166] drmOpenByBusid: drmOpenMinor returns -1
[   917.166] drmOpenDevice: node name is /dev/dri/card8
[   917.172] drmOpenByBusid: drmOpenMinor returns -1
[   917.172] drmOpenDevice: node name is /dev/dri/card9
[   917.177] drmOpenByBusid: drmOpenMinor returns -1
[   917.177] drmOpenDevice: node name is /dev/dri/card10
[   917.183] drmOpenByBusid: drmOpenMinor returns -1
[   917.183] drmOpenDevice: node name is /dev/dri/card11
[   917.188] drmOpenByBusid: drmOpenMinor returns -1
[   917.188] drmOpenDevice: node name is /dev/dri/card12
[   917.193] drmOpenByBusid: drmOpenMinor returns -1
[   917.193] drmOpenDevice: node name is /dev/dri/card13
[   917.199] drmOpenByBusid: drmOpenMinor returns -1
[   917.199] drmOpenDevice: node name is /dev/dri/card14
[   917.204] drmOpenByBusid: drmOpenMinor returns -1
[   917.204] drmOpenDevice: node name is /dev/dri/card15
[   917.210] drmOpenByBusid: drmOpenMinor returns -1
[   917.210] drmOpenDevice: node name is /dev/dri/card0
[   917.210] drmOpenDevice: open result is 8, (OK)
[   917.210] drmGetBusid returned ''
[   917.210] (II) EMGD(0): Chipset: "Intel SCH US15 Chipset"
[   917.210] (II) EMGD(0): Detected kernel module from EMGD build 3398
[   917.211] (II) EMGD(0): Checking for new style options
[   917.211] (II) EMGD(0): Processing version 7.0 options
[   917.211] (II) EMGD(0): Using configuration 1
[   917.211] (II) EMGD(0): Checking for US15 specific configuration.
[   917.211] (II) EMGD(0): Cannot find vBIOS config id
[   917.211] (II) EMGD(0): Falling back to first available id: 1
[   917.211] (II) EMGD(0): Checking for non-chipset specific configuration.
[   917.211] (II) EMGD(0): Setting port_order to 40000
[   917.211] (II) EMGD(0): Allocated local dtd for port=3 dtdid=1
[   917.211] (II) EMGD(0): Option processing done!
[   917.389] (II) EMGD(0): Valid Display Configurations:
[   917.389] (II) EMGD(0):   DC: 0x00000041
[   917.389] (II) EMGD(0):   DC: 0x00000000
[   917.389] (II) EMGD(0): Using Display Configuration 0x00000041
[   917.390] (==) EMGD(0): Depth 24, (--) framebuffer bpp 32
[   917.390] (==) EMGD(0): Using gamma correction (1.0, 1.0, 1.0)
[   917.390] (II) EMGD(0): 1 modes passed validation checks
[   917.390] (--) EMGD(0): Virtual size is 800x480 (pitch 0)
[   917.390] (**) EMGD(0): *Built-in mode "800x480": 33.3 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
[   917.390] (II) EMGD(0): Modeline "800x480"x60.0   33.26  800 840 968 1055  480 489 495 524 (31.5 kHz)
[   917.390] (==) EMGD(0): DPI set to (96, 96)
[   917.390] (II) Loading sub module "fb"
[   917.390] (II) LoadModule: "fb"
[   917.390] (II) Loading /usr/lib/xorg/modules/libfb.so
[   917.396] (II) Module fb: vendor="X.Org Foundation"
[   917.396]    compiled for 1.9.5, module version = 1.0.0
[   917.396]    ABI class: X.Org ANSI C Emulation, version 0.4
[   917.396] (II) Loading sub module "ramdac"
[   917.396] (II) LoadModule: "ramdac"
[   917.396] (II) Module "ramdac" already built-in
[   917.396] (II) EMGD(0): General Driver Configuration Options
[   917.396] (II) EMGD(0):   PCF Version:            7.00
[   917.396] (II) EMGD(0):   Configuration ID:       1
[   917.396] (II) EMGD(0): Primary Display Configuration Options
[   917.396] (II) EMGD(0):   VideoRam (Pixmap Cache): 32768
[   917.396] (II) EMGD(0):   PORT AND DISPLAY OPTIONS
[   917.396] (II) EMGD(0):     Port Order:           40000
[   917.396] (II) EMGD(0):     Display Config:       Single
[   917.396] (II) EMGD(0):     Display Detect:       Off
[   917.396] (II) EMGD(0):     FB Blend Overlay:     Off
[   917.396] (II) EMGD(0):     Subpicture On FB:     Off
[   917.396] (II) EMGD(0):     Gang DVO:             Off
[   917.396] (II) EMGD(0):     Refresh Rate:         0
[   917.396] (II) EMGD(0):     Clone Width:          0
[   917.396] (II) EMGD(0):     Clone Height:         0
[   917.396] (II) EMGD(0):     Clone Refresh:        0
[   917.396] (II) EMGD(0):   FRAMEBUFFER OPTIONS
[   917.397] (II) EMGD(0):     Shadow FB:            Off
[   917.397] (II) EMGD(0):     Tear FB:              On
[   917.397] (II) EMGD(0):     Resize:               Off
[   917.397] (II) EMGD(0):    GL TEXTURE STREAM OUTPUT:         Off
[   917.397] (II) EMGD(0):   FRAMEBUFFER ORIENTATION OPTIONS
[   917.397] (II) EMGD(0):     Rotation:             0 degrees
[   917.397] (II) EMGD(0):     Flip:                 Off
[   917.397] (II) EMGD(0):   HARDWARE ACCELERATION OPTIONS
[   917.397] (II) EMGD(0):     HW 2D Accel:          On
[   917.397] (II) EMGD(0):     HW Cursor:            On
[   917.397] (II) EMGD(0):   XVIDEO OPTIONS
[   917.397] (II) EMGD(0):     XVideo:               On
[   917.397] (II) EMGD(0):     XVideoBlend:          On
[   917.397] (II) EMGD(0):     XVideoMC:             Off
[   917.397] (II) EMGD(0):     XVideoKey:            0xff00ff00
[   917.397] (II) EMGD(0):     Overlay Gamma Red:    0x100
[   917.397] (II) EMGD(0):     Overlay Gamma Green:  0x100
[   917.397] (II) EMGD(0):     Overlay Gamma Blue:   0x100
[   917.397] (II) EMGD(0):     Overlay Brightness:   0x8000
[   917.397] (II) EMGD(0):     Overlay Contrast:     0x8000
[   917.397] (II) EMGD(0):     Overlay Saturation:   0x8000
[   917.397] (II) EMGD(0):     Overlay Hue:             0x8000
[   917.397] (II) EMGD(0):     DRI:                  Off
[   917.397] (II) EMGD(0):     DRI2:                 On
[   917.397] (II) EMGD(0):     EDID:                 On
[   917.397] (II) EMGD(0):   QUICKBOOT OPTIONS
[   917.397] (II) EMGD(0):     QuickBoot:            1
[   917.397] (II) EMGD(0):     Seamless:             Off
[   917.397] (II) EMGD(0):     Video Input:          0
[   917.397] (II) EMGD(0):     Splash Screen:        Off
[   917.397] (II) EMGD(0):     Freeze FB:        Off
[   917.397] (II) EMGD(0):    INTERRUPT OPTIONS
[   917.397] (II) EMGD(0):      Polling:             Off
[   917.397] (II) EMGD(0):   GLOBAL PER PORT OPTIONS
[   917.397] (II) EMGD(0):   Port 2            (null)
[   917.397] (II) EMGD(0):      Multi-DVO:      Off
[   917.397] (II) EMGD(0):      Centering:      Off
[   917.398] (II) EMGD(0):      RenderScale:    Off
[   917.398] (II) EMGD(0):      EDID:           Off
[   917.398] (II) EMGD(0):      EDID Avail:     0x5
[   917.398] (II) EMGD(0):      EDID Not Avail: 0x5
[   917.398] (II) EMGD(0):      PANEL INFORMATION
[   917.398] (II) EMGD(0):         FP width:     0
[   917.398] (II) EMGD(0):         FP height:    0
[   917.398] (II) EMGD(0):         BKLT Enable:  0
[   917.398] (II) EMGD(0):         BKLT Method:  0
[   917.398] (II) EMGD(0):         BKLT T1:      0
[   917.398] (II) EMGD(0):         BKLT T2:      0
[   917.398] (II) EMGD(0):         BKLT T3:      0
[   917.398] (II) EMGD(0):         BKLT T4:      0
[   917.398] (II) EMGD(0):         BKLT T5:      0
[   917.398] (II) EMGD(0):         GPIO Pin VDD: 0
[   917.398] (II) EMGD(0):         GPIO Pin VEE: 0
[   917.398] (II) EMGD(0):         GPIO Pin BKLT:0
[   917.398] (II) EMGD(0):         DVO i2c pin:  0
[   917.398] (II) EMGD(0):         DVO i2c DAB:  0
[   917.398] (II) EMGD(0):         DVO i2c speed:0
[   917.398] (II) EMGD(0):         DVO ddc pin:  0
[   917.398] (II) EMGD(0):         DVO ddc speed:0
[   917.398] (II) EMGD(0):      Number DTD's:   0
[   917.398] (II) EMGD(0):      Number Attr's:  0
[   917.398] (II) EMGD(0):   Port 4            LVDS
[   917.398] (II) EMGD(0):      Multi-DVO:      Off
[   917.398] (II) EMGD(0):      Rotation:       0 degrees
[   917.398] (II) EMGD(0):      Flip:           Off
[   917.398] (II) EMGD(0):      Centering:      Off
[   917.398] (II) EMGD(0):      EDID Avail:     0x0
[   917.398] (II) EMGD(0):      EDID Not Avail: 0x4
[   917.399] (II) EMGD(0):         BKLT T4:      0
[   917.399] (II) EMGD(0):         BKLT T5:      0
[   917.399] (II) EMGD(0):         GPIO Pin VDD: 0
[   917.399] (II) EMGD(0):         GPIO Pin VEE: 0
[   917.399] (II) EMGD(0):         GPIO Pin BKLT:0
[   917.399] (II) EMGD(0):         DVO i2c pin:  0
[   917.399] (II) EMGD(0):         DVO i2c DAB:  0
[   917.399] (II) EMGD(0):         DVO i2c speed:0
[   917.399] (II) EMGD(0):         DVO ddc pin:  0
[   917.399] (II) EMGD(0):         DVO ddc speed:0
[   917.399] (II) EMGD(0):      Number DTD's:   1
[   917.399] (II) EMGD(0):        1-width:       800
[   917.399] (II) EMGD(0):        1-height:      480
[   917.399] (II) EMGD(0):        1-refresh:     0
[   917.399] (II) EMGD(0):        1-dclk:        33264
[   917.399] (II) EMGD(0):        1-horz total:  0
[   917.399] (II) EMGD(0):        1-horz b_start:799
[   917.399] (II) EMGD(0):        1-horz b_end:  1055
[   917.399] (II) EMGD(0):        1-horz s_start:840
[   917.399] (II) EMGD(0):        1-horz s_end:  968
[   917.399] (II) EMGD(0):        1-vert total:  0
[   917.399] (II) EMGD(0):        1-vert b_start:479
[   917.399] (II) EMGD(0):        1-vert b_end:  524
[   917.399] (II) EMGD(0):        1-vert s_start:489
[   917.399] (II) EMGD(0):        1-vert s_end:  495
[   917.399] (II) EMGD(0):        1-flags:       0x20000
[   917.399] (II) EMGD(0):      Number Attr's:  7
[   917.399] (==) Depth 24 pixmap format is 32 bpp
[   917.405] drmOpenDevice: node name is /dev/dri/card0
[   917.405] drmOpenDevice: open result is 9, (OK)
[   917.405] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.406] drmOpenDevice: node name is /dev/dri/card0
[   917.406] drmOpenDevice: open result is 9, (OK)
[   917.406] drmOpenByBusid: drmOpenMinor returns 9
[   917.406] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.406] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.480] drmOpenDevice: node name is /dev/dri/card0
[   917.480] drmOpenDevice: open result is 9, (OK)
[   917.480] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.480] drmOpenByBusid: drmOpenMinor returns 9
[   917.480] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.480] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.481] drmOpenDevice: node name is /dev/dri/card0
[   917.481] drmOpenDevice: open result is 9, (OK)
[   917.481] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.481] drmOpenByBusid: drmOpenMinor returns 9
[   917.481] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.481] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.482] drmOpenDevice: node name is /dev/dri/card0
[   917.482] drmOpenDevice: open result is 9, (OK)
[   917.482] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.483] drmOpenByBusid: drmOpenMinor returns 9
[   917.483] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.483] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.512] (II) EMGD(0): [DRI2] Setup complete
[   917.512] (II) EMGD(0): [DRI2]   DRI driver: emgd
[   917.512] (II) EMGD(0): DRI2 initialization complete.
[   917.524] (II) UXA(0): Driver registered support for the following operations:
[   917.524] (II)         solid
[   917.524] (II)         copy
[   917.524] (II)         composite (RENDER acceleration)
[   917.524] (II) EMGD(0): [hal to drm] Communication With DRM Failed
[   917.524] (II) EMGD(0): Video acceleration initialization complete
[   917.524] (==) EMGD(0): Backing store disabled
[   917.549] drmOpenDevice: node name is /dev/dri/card0
[   917.550] drmOpenDevice: open result is 10, (OK)
[   917.550] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.550] drmOpenDevice: node name is /dev/dri/card0
[   917.550] drmOpenByBusid: drmOpenMinor returns 10
[   917.550] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.550] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.554] (II) EMGD(0): Hardware Cursor Initialization complete.
[   917.554] (==) EMGD(0): Silken mouse enabled
[   917.554] (==) EMGD(0): DPMS enabled
[   917.556] (==) RandR enabled
[   917.556] (II) Initializing built-in extension Generic Event Extension
[   917.556] (II) Initializing built-in extension SHAPE
[   917.556] (II) Initializing built-in extension MIT-SHM
[   917.556] (II) Initializing built-in extension XInputExtension
[   917.556] (II) Initializing built-in extension XTEST
[   917.556] (II) Initializing built-in extension BIG-REQUESTS
[   917.556] (II) Initializing built-in extension SYNC
[   917.556] (II) Initializing built-in extension XKEYBOARD
[   917.557] (II) Initializing built-in extension XC-MISC
[   917.557] (II) Initializing built-in extension XINERAMA
[   917.557] (II) Initializing built-in extension XFIXES
[   917.557] (II) Initializing built-in extension XFree86-Bigfont
[   917.557] (II) Initializing built-in extension RENDER
[   917.557] (II) Initializing built-in extension RANDR
[   917.557] (II) Initializing built-in extension COMPOSITE
[   917.557] (II) Initializing built-in extension DAMAGE
[   917.690] drmOpenDevice: node name is /dev/dri/card0
[   917.691] drmOpenDevice: open result is 10, (OK)
[   917.691] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.691] drmOpenDevice: node name is /dev/dri/card0
[   917.691] drmOpenByBusid: drmOpenMinor returns 10
[   917.691] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.691] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.721] drmOpenDevice: node name is /dev/dri/card0
[   917.721] drmOpenDevice: open result is 10, (OK)
[   917.721] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.721] drmOpenByBusid: drmOpenMinor returns 10
[   917.721] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.721] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.730] drmOpenDevice: node name is /dev/dri/card0
[   917.730] drmOpenDevice: open result is 11, (OK)
[   917.730] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.730] drmOpenByBusid: drmOpenMinor returns 11
[   917.730] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.730] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.731] drmOpenByBusid: Searching for BusID PCI:00:02:00
[   917.731] drmOpenDevice: node name is /dev/dri/card0
[   917.731] drmOpenDevice: open result is 11, (OK)
[   917.731] drmOpenByBusid: drmOpenMinor returns 11
[   917.731] drmOpenByBusid: Interface 1.4 failed, trying 1.1
[   917.731] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[   917.765] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[   917.765] (II) AIGLX: enabled GLX_INTEL_swap_event
[   917.765] (II) AIGLX: enabled GLX_SGI_make_current_read
[   917.765] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[   917.765] (II) AIGLX: Loaded and initialized /usr/lib/dri/emgd_dri.so
[   917.765] (II) GLX: Initialized DRI2 GL provider for screen 0
[   917.994] (II) config/udev: Adding input device HDA Intel MID Mic (/dev/input/event2)
[   917.994] (II) No input driver/identifier specified (ignoring)
[   917.995] (II) config/udev: Adding input device HDA Intel MID Mic (/dev/input/event3)
[   917.995] (II) No input driver/identifier specified (ignoring)
[   917.996] (II) config/udev: Adding input device HDA Intel MID Mic (/dev/input/event4)
[   917.996] (II) No input driver/identifier specified (ignoring)
[   917.997] (II) config/udev: Adding input device HDA Intel MID Line-out (/dev/input/event5)
[   917.997] (II) No input driver/identifier specified (ignoring)
[   917.997] (II) config/udev: Adding input device HDA Intel MID Headphone (/dev/input/event6)
[   917.998] (II) No input driver/identifier specified (ignoring)
[   918.003] (II) config/udev: Adding input device AmSC OpenPeak Touchscreen Hyup02 (/dev/input/event1)
[   918.003] (**) AmSC OpenPeak Touchscreen Hyup02: Applying InputClass "evdev pointer catchall"
[   918.003] (II) LoadModule: "evdev"
[   918.003] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[   918.006] (II) Module evdev: vendor="X.Org Foundation"
[   918.006]    compiled for 1.9.5, module version = 2.3.3
[   918.006]    Module class: X.Org XInput Driver
[   918.006]    ABI class: X.Org XInput driver, version 11.0
[   918.007] (**) AmSC OpenPeak Touchscreen Hyup02: always reports core events
[   918.007] (**) AmSC OpenPeak Touchscreen Hyup02: Device: "/dev/input/event1"
[   918.007] (II) AmSC OpenPeak Touchscreen Hyup02: Found 3 mouse buttons
[   918.007] (II) AmSC OpenPeak Touchscreen Hyup02: Found absolute axes
[   918.007] (II) AmSC OpenPeak Touchscreen Hyup02: Found x and y absolute axes
[   918.007] (II) AmSC OpenPeak Touchscreen Hyup02: Configuring as mouse
[   918.007] (**) AmSC OpenPeak Touchscreen Hyup02: YAxisMapping: buttons 4 and 5
[   918.007] (**) AmSC OpenPeak Touchscreen Hyup02: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[   918.007] (II) XINPUT: Adding extended input device "AmSC OpenPeak Touchscreen Hyup02" (type: MOUSE)
[   918.007] (II) AmSC OpenPeak Touchscreen Hyup02: initialized for absolute axes.
[   918.008] (II) config/udev: Adding input device AmSC OpenPeak Touchscreen Hyup02 (/dev/input/js0)
[   918.008] (II) No input driver/identifier specified (ignoring)
[   918.009] (II) config/udev: Adding input device AmSC OpenPeak Touchscreen Hyup02 (/dev/input/mouse1)
[   918.009] (II) No input driver/identifier specified (ignoring)
[   918.016] (II) config/udev: Adding input device Logitech Unifying Device. Wireless PID:400e (/dev/input/event0)
[   918.017] (**) Logitech Unifying Device. Wireless PID:400e: Applying InputClass "evdev pointer catchall"
[   918.017] (**) Logitech Unifying Device. Wireless PID:400e: Applying InputClass "evdev keyboard catchall"
[   918.017] (**) Logitech Unifying Device. Wireless PID:400e: always reports core events
[   918.017] (**) Logitech Unifying Device. Wireless PID:400e: Device: "/dev/input/event0"
[   918.017] (II) Logitech Unifying Device. Wireless PID:400e: Found 20 mouse buttons
[   918.017] (II) Logitech Unifying Device. Wireless PID:400e: Found scroll wheel(s)
[   918.017] (II) Logitech Unifying Device. Wireless PID:400e: Found relative axes
[   918.017] (II) Logitech Unifying Device. Wireless PID:400e: Found x and y relative axes
[   918.017] (II) Logitech Unifying Device. Wireless PID:400e: Found absolute axes
[   918.017] (II) Logitech Unifying Device. Wireless PID:400e: Found keys
[   918.017] (II) Logitech Unifying Device. Wireless PID:400e: Configuring as mouse
[   918.017] (II) Logitech Unifying Device. Wireless PID:400e: Configuring as keyboard
[   918.017] (**) Logitech Unifying Device. Wireless PID:400e: YAxisMapping: buttons 4 and 5
[   918.017] (**) Logitech Unifying Device. Wireless PID:400e: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[   918.017] (II) XINPUT: Adding extended input device "Logitech Unifying Device. Wireless PID:400e" (type: KEYBOARD)
[   918.017] (**) Option "xkb_rules" "evdev"
[   918.017] (**) Option "xkb_model" "pc105"
[   918.017] (**) Option "xkb_layout" "us"
[   918.018] (II) Logitech Unifying Device. Wireless PID:400e: initialized for relative axes.
[   918.018] (WW) Logitech Unifying Device. Wireless PID:400e: ignoring absolute axes.
[   918.019] (II) config/udev: Adding input device Logitech Unifying Device. Wireless PID:400e (/dev/input/mouse0)
[   918.019] (II) No input driver/identifier specified (ignoring)
-=xXx=-
Re: EMGD Xorg and Linux.
Post by -=xXx=- » Sun Mar 11, 2018 11:52 pm
I think this shows the problem
Tried with 1.9.0 same problem.
-=xXx=-
Post by -=xXx=- » Tue Mar 13, 2018 12:53 am
Problem appere cause of some broken links during the installation.
rbshep
Post by rbshep » Sat Dec 01, 2018 2:36 pm
I'm no expert in this at all, but i know on PowerPC macs with radeon graphics cards, I get an error from Xorg about the (in this case, radeon r100 - r300 series) card not having a VGA Bios - as in this case, the code on the card's ROM is built for OpenFirmware. The radeon drivers are more tolerant though, and X starts and works fine, (for the most part).
Now as the drivers are built by intel, the joggler uses EFI instead of a conventional BIOS, and most netbooks with Poulsbo would have used a BIOS (or EFI with CSM pretending to be a conventional bios), maybe the driver is failing due to not being able to find the VGA bios? I know the graphics on EFI is different to legacy VGA - using either UGA or GOP to manage the framebuffer.
Also, i'm enjoying your 16.04 build with the 4.4 kernel, i'd try and help get it based on 16.04 if i knew what i was doing ;) Built kernels on gentoo before, but never on debian / ubuntu, let alone building packages!!
