Images 4 Openframe 2 devices
shadow1901
Post by shadow1901 »
hi all
What kind of images are working on openframe 2 (the device with speakers in front) devices?
At moment, I use the squeezeplayer os.
My goal is, that I can use an image with working sound, browser, squeezeplayer and an good touchscreen keyboard (it should not have small keyboard keys).
I doesn't want use an external keyboard and mouse. With the xubuntu/ubuntu version, it isn't possible work without an mouse and keyboard. All buttons are to small.
I try to build an version on ubuntu touch (unity 8), but I can't install.
thanks for help Shadow1901
Re: Images 4 Openframe 2 devices
shadow1901 wrote:hi all
Hi Shadow 1901
There is a version of unity Touch knocking around but it's very old , I have a copy I think .It's very old though it does work.
ThisImage
shadow1901
Thanks for answer
can I have some images for the device.
the netbook image target link isn't avalaible.
Think I have it on a hard drive I'll have a look tonight :-) think I got it off @Mickchip
hawsey wrote:Think I have it on a hard drive I'll have a look tonight :-) think I got it off @Mickchip
Found it on a drive , downloading to Dropbox then I'll pm you a link .
Pm sent .
hawsey wrote:Pm sent .
Also Mate desktop could be installed on top of Buzz 's great Xubuntu build which would be more up to date .
It's an old post as well so there could beba more up to date version as well .
And increasing the thermal.psv value will stop throttling ( with possible risks ) :-)
http://www.omgubuntu.co.uk/2014/08/inst ... -14-04-lts
Thank you Hawsey. I installed Mate desktop over Buzz's Ubuntu build. It took maybe 25 minutes to upgrade on my hardware modded Openpeak 1 with RTC battery mods, USB Hub mode, SROM NIC update and SSD drive. The machine is using both the eMMC and the 16 Gb SSD card.
root@ICS-Jog-UB-01:~# df -l
Filesystem     1K-blocks    Used Available Use% Mounted on
udev              244268       4    244264   1% /dev
tmpfs              50460     764     49696   2% /run
/dev/sda3       15090724 6909124   7415304  49% /
none                   4       0         4   0% /sys/fs/cgroup
none                5120       0      5120   0% /run/lock
none              252288      88    252200   1% /run/shm
none              102400      24    102376   1% /run/user
/dev/uba1          61302   24296     37006  40% /boot
/dev/uba2        7669144 4480080   2799484  62% /home
tmpfs             139264       0    139264   0% /home/ramdisk
I haven't figured out yet how to boot in Mate and it is still booting to configured with Buzz's Ubuntu desktop. No ill effects from what I can tell. Note that this is on an Openpeak 1 which is similiar to the Openpeak 2 except it looks like an O2 Joggler except it has a bit more hardware to the base and a massive heat sink covering the whole motherboard (like the Openpeak 2).
Nice one Pete :-) have you a picture of this model ?
Well it looks exactly like an O2 Joggler except that it is labeled Openpeak. I got Mate to load by logging out and relogging in.
I will take a picture of the device today and write Buzz's Ubuntu on a stick and try it with the Openpeak 2.
Don't think I've seen one of those Pete, all Jogglers over here .
It is the mini version of the Openpeak 2 and looks identical to the O2 Joggler except for the label in the back and the imprint of Openpeak on it.
Inside it is a bit different.
By default it has the ZIF connector for the SSD card, DECT chip, Zigbee chip, microphone and a metal heat sink over almost the entire motherboard.
I do have a prototype of the O2 Joggler using this Openpeak 1 marked O2 except that the stuff above has been removed. I do not recall where I got it from...thinking it came from Openpeak....never touched it to keep it intact as I received it. I think I have posted pictures of the motherboard here a while ago.
It is these primarily now on line running embedded Windows using Seabios for my home automation stuff and they work fine wired or wirelessly.
Ubuntu Linux using the EFI bios for Squeezeplayers et al. - modded these with RTC and USB hubs on the backs of them.
Andrew1971
Post by Andrew1971 »
Hi All
Does anyone have the netbook remix for the joggler that would be good.
Many Thanks
Andrew
I'll dig it out tonight for you Andrew , it is very old and you would do much better building your own based on BuZz's base or Xubuntu but I'll get you a link :-)
Andrew1971
Cheer's Gary your a star. I do like the UNR desktop I have no idea to put on xubuntu.
Many Thank's
Andrew
Andrew1971 wrote:Cheer's Gary your a star. I do like the UNR desktop I have no idea to put on xubuntu.
Many Thank's
Andrew
No probs Andrew ,
https://www.dropbox.com/sh/f2792g7f1e2k ... 97kQa?dl=0
It's the UNR , 3.6 gig file , let me know when you have it :-)
Andrew1971
Hi Gary
I have tried several time's to get it. But it keeps stopping at 6-8%. Tried different web browser still the same.
Could UNR desktop work on Buzz's Ubuntu if so how is it done.
Many Thank's
Andrew
Andrew1971 wrote:Hi Gary
Many Thank's
Andrew
Hi Andrew , not sure why that's happening :-( I'm looking at the file in my Dropbox and it's 3.6gig or thereabouts .
I got it off another forum member , maybe they will see this post and link you .
@pete has installed a similar desktop in Xubuntu but I forget it's name , it's in the threads recently though .
