Safety Jogger Nordic S3 work boots for labor protection
hoanghuynh
Post by hoanghuynh »
workwearmag introduce Safety Jogger Nordic S3 boots imported genuine from Belgium multi-function protective with a modern design suitable in the industrial working environment.
Application of the Safety Jogger Nordic S3 advocate for labor protection
- Waterproof, anti-slip, anti-finger stamping.
- Against nails, oils, chemicals.
- Antistatic.
- Suitable for use in construction sites, factories, mechanical workshops, mines, drilling rigs, industrial parks.
The outstanding feature of Safety Jogger Nordic S3 boots
- Manufactured by EN ISO 20345 S3.
- For men, with high neckline, sporty, youthful, and dynamic design.
- The outer shell is made of real leather, the inner surface is lined with fur
- Toes with anti-stamping composite materials.
- Equipped with SJ Flex pads.
- With a zipper
- Shoe sole 2 layers PU oil-resistant, anti-slip SRC, heat resistant.
- Footpads are made of smooth E.V.A material, helping to circulate the air.
- Available in 38-47 sizes to suit all foot sizes.
Note during use of Safety Jogger Nordic S3 boots
- Do not use high heat to dry shoes.
- When shoes are wet, they can be dried by crushing newspapers and stuffing them inside shoes, drying shoes in the shade.
- Removable E.V.A liner for cleaning.
- It is recommended to change shoes when: the embossed details on the sole are worn out (affecting the slip resistance); after stepping on the nail or the outer skin is torn (insulation affects).
With its advantages, Safety Jogger Nordic S3 safety shoes are the first choice of users when looking to buy boots. Order today or check out other Safety Jogger work shoes at: or
Re: IPv6 Kernel module for Joggler?
I am not that technical so possibly not the one to help you are you not able to connect to the internet ? Is that your issue ?
Not out of the box.
Here too have updated all of my Jogglers Realtek NIC SRom's. Original O2 Jogglers came with non programmed Realtek SROMs.
That said Buzz's Ubuntu build runs IP6 fine.
Jog-UB-01:~# [ -f /proc/net/if_inet6 ] && echo 'IPv6 ready system!' || echo 'No IPv6 support found! Compile the kernel!!'
IPv6 ready system!
Jog-UB-01:~#
Jog-UB-01:~# netstat -ps -6
Ip6:
1772 total packets received
0 incoming packets discarded
1266 incoming packets delivered
0 forwarded
545 requests sent out
42 dropped because of missing route
1264 incoming multicast packets
543 outgoing multicast packets
Ip6InOctets: 151973
Ip6OutOctets: 41427
Ip6InMcastOctets: 115401
Ip6OutMcastOctets: 41287
Icmp6:
795 ICMP messages received
0 input ICMP message failed.
514 ICMP messages sent
ICMP input histogram:
group member queries: 437
group member responses: 354
neighbour advertisement: 4
ICMP output histogram:
group member responses: 506
router solicits: 3
neighbor solicits: 1
Icmp6OutMLDv2Reports: 4
Icmp6InType130: 437
Icmp6InType131: 354
Icmp6InType136: 4
Icmp6OutType131: 506
Icmp6OutType133: 3
Icmp6OutType135: 1
Icmp6OutType143: 4
Udp6:
355 packets received
0 packets to unknown port received.
0 packet receive errors
29 packets sent
UdpLite6:
Tcp:
14 active connections openings
1 passive connection openings
2 failed connection attempts
0 connection resets received
1 connections established
6615 segments received
1427 segments send out
0 segments retransmited
0 bad segments received.
2 resets sent
