New Here
Rory
New Here
Post by Rory »
Hello, I am new here, I have recently acquired several joggers from eBay to mess around with and have tried to follow the instructions to add new software from this site but I cannot seem to get the joggler to do anything other than load the original O2 Software... Perhaps I'm being really stupid? I am using a MacBook.... Does that matter?I have bought new USB sticks etc as many have mentioned that the type of stick can be an issue but still nothing... Any help would be appreciated...
Re: New Here
Welcome to the Joggler forum Rory.
no
These should work.
The EFI boot sticks are a bit fussy.
Rory
Re: New Here
Post by Rory »
Thanks for the reply - I have loaded the stuff onto the various sticks, unplugged the joggler, plugged in the stick, plugged in the joggler and it just boots as normal...
Re: New Here
Have you purchased O2 Jogglers or Openpeak tabletop tablets?
I've seen issues with the efi boot rom and boot on the MMC preventing the USB from being recognized.
Are the Jogglers booting to an updated MMC or original MMC?
Try using this program to write an image to a USB stick:
Etcher at https://etcher.io/
and the blind typing thing using a USB hub with the boot stick and a USB keyboard.
Hit the esc key continuously while booting. Wait for the keyboard LED to flash on the second time then type:
fs1:
and enter a couple of times
then type:
boot
and enter
See what happens. You cannot break anything.
Rory
Re: New Here
Post by Rory »
i bought O2 Jogglers with the original software, ill give this a go!
Re: New Here
Rory wrote: Mon Jun 12, 2017 5:28 am i bought O2 Jogglers with the original software, ill give this a go!
hi Rory, try this first on one of the jogglers and then try squeezeplay
http://birdslikewires.uk/openpeak-firmware
Ronnie
Re: New Here
Welcome Rory , are you plugging straight in to the side port ?
Rory
Re: New Here
Post by Rory »
Yes straight into the side port...
Re: New Here
How are you writing the image to the usb stick :-)
Document it here so someone with a Mac can see where your going wrong .
Rory
Re: New Here
Post by Rory »
Ok so i used etcher to load the birds like wires reflash then tried copying over the latest openpeak img but the partition only allows 500mb so there is not enough room for the 1.1gb image.... HELP!?
Rory
Re: New Here
Post by Rory »
Ok so i have Version 30300 from birds like wires running but none of the apps work... Now trying to load PnP III but the joggler seems to ignore the USB when loaded with it.....
Re: New Here
If I remember right PPP III takes ages to work , you make your stick up , plug it in , switch on then go away for a cuppa , 30 mins later come back and it will be done :-) it stops and starts a few times and looks like it is not working but it is .
Re: New Here
Now that you are up and running what function would you like the Joggler to do for you ?
There is no denying that PNPIII is finger friendly and works well .
There is also Squeezeplay OS for music
Or Xubuntu , a full blown Linux distribution which runs Squeezeplay also and Kodi amoungst other things .
Most boot straight off a usb stick and you do not overwrite the internal with them like PNPIII .
Rory
Re: New Here
Post by Rory »
id like to get the pnpiii working but when i plug in the usb it just loads the 30300 version....
Re: New Here
Yup; you are going have to read this post and install and then maybe adjust the build as there are recent issues.
viewtopic.php?f=2&t=555
Current Issues can be resolved.
Read this post and make your adjustments.
mcp.php?i=main&mode=post_details&f=2&p= ... a96cf07b03
Rory
Re: New Here
Post by Rory »
I've managed to load android on it... looks good
Re: New Here
Good news Rory!
Re: New Here
Nice one Rory :-)
Other ones to try on Efi boot are Xubuntu ( Linux ) , Squeezeplay OS for music , XP ( some where ) just ask ,
For PNP III look through the PNP thread and post on there , you will get there eventually .
