Native OS Icons
Native OS Icons
Can i ask for people to kindly upload the icons they are using on the joggler's native OS. No specific ones, just any non default ones, so we can pick and choose and make our Joggler's more pretty.
Re: Native OS Icons
Hi! I'll get them uploaded somewhere today or tomorrow. They are actually just .png files renamed .swf.
Re: Native OS Icons
I've popped an archive of my icons at
http://dl.dropbox.com/u/24506919/Joggle ... 202011.tar
Just replace the icon.swf with the desired .png file by copying it into the correct place and renaming it icon.swf and it should work after restarting tango.
Back up the original icon.swf first!
Re: Native OS Icons
Well holy moly, I never knew you could do that!offbeatdave wrote:They are actually just .png files renamed .swf.
Re: Native OS Icons
Haha nor did i, i wouldn't of asked otherwise ...
Re: Native OS Icons
So... in that case how do you get an 'pressed' state? The icon should darken when tapped.spoyser wrote:Well holy moly, I never knew you could do that!offbeatdave wrote:They are actually just .png files renamed .swf.
Re: Native OS Icons
They don't! I'm not fussed about that though as I my fingers tend to cover the area taken up by the icon anyway!roobarb! wrote: So... in that case how do you get an 'pressed' state? The icon should darken when tapped.
Re: Native OS Icons
Actually it wouldn't be that difficult to create a swf that loads in a fixed filenamed png in the same directory as the swf and darkens it on pressing.
This would allow people to have functioning buttons without having to compile the swf simply by putting the swf and whatever png they want in the same directory!
I might have a look when I get a spare moment!
Re: Native OS Icons
I got a moment and gave it a try, unfortunately doesn't work looks like the tango frontend just loads in the swf as a button resource rather than actually allowing it to execute, which I guess makes sense.spoyser wrote:Actually it wouldn't be that difficult to create a swf that loads in a fixed filenamed png in the same directory as the swf and darkens it on pressing.
Re: Native OS Icons
Guys, wasn't sure where to post this, but can anyone please assist me? I've been loading some apps on the native OS on a second joggler and found that it didnt full up the second page of icons before it put the next apps onto a third page..
So I have the native OS's first page, then I hit the right button and see a 2/3 full page of icons and have to hit the right key again to view a third screen with the next icons on. Can anyone tell me how to reposition them so they all sit on the second screen?
EDIT: Found I had to hold an icon to enter the move menu..... Please ignore the above
Re: Native OS Icons
is there any buy photoshop special for the icon files for joggler ? cheap photoshop
