Ok here I go, this is to install Spotify (free windows version, so no subscription requered!!)
(you may need to resize your root partition for extra space)
ssh into your joggler running ubuntu 11.04
sudo wget "http://deb.playonlinux.com/public.gpg"
wget -q "http://deb.playonlinux.com/public.gpg" -O- | sudo apt-key add -
sudo wget http://deb.playonlinux.com/playonlinux_natty.list -O /etc/apt/sources.list.d/playonlinux.list
sudo apt-key add public.gpg
sudo apt-get update
sudo apt-get install playonlinux (accept or answer yes to any questions)
Reboot Joggler
Once Restarted Go to:
Applications >> Games >> PlayOnLinux
Now Follow the Wizzard and setup PlayOnLinux
Once PlayOnLinux is setup, Click install, then type "spotify",
once you see the spotify application, double click it and install spotify, (free) !!
Please note: im a linux newbee, if anyone can make a better set of instructions, please feel free!
