Recommend a usb ?
Recommend a usb ?
Can anyone recommend a 16 GB usb guaranteed to work on a Joggler. I need a usb to backup my existing 16 gb verbatim nano (no longer available)
Re: Recommend a usb ?
Is this the one ?
https://www.amazon.co.uk/Verbatim-97464 ... BATIM+NANO
If they wont ship to Spain let me know and i will sort ...
Mine is Store n Go - this looks like a later version as Store n Stay! Should I Stay or Should I Go?
I'll check it out on amazon es.
cheers
cheers
Will do .
Any news on the Joggler front?
Hmm slowly , I just had a go tonight and managed to change my password then get logged on to LMS on my PC , in 3rd party add ons I can see upnp bridge un ticked so I ticked it .
Now when I look on my Joggler with LMS installed I can't see the Upnp app ?
Sent by SlimKat FirePhone
No. You have to configure the upnpbridge using the lms gui. You see nothing on the Joggler interface.
Use a browser - go to address JogglerIP:9000 (eg. http://192.168.0.27:9000)
At bottom left - Settings - Advanced - UPNP/DLNABridge --- this opens the bridge config page.
Just check you can get that far .... we'll take it from there.
OK
When I log in to LMS GUI as you say , under advanced I only have Artwork , Artwork folder , Guess Tags Formats ...
at the top left, there's a dropdown - use that . UPNPbridge is the last item on the list.
Get there - and can we stop until tomorrow. Been a heavy week here - shattered.
Cheers appreciate it , speak tomorrow , I've given up tonight .thx
Still no further forward ha ha , I'll continue this on the Jongo thread in case it helps others .
usb arrived (sent from Italy !!!) - system copied - and it works! Excellent.hawsey wrote:I would just Clash on and buy one
Might get one myself ....
Tied up over next few days with hospital .... will check back now & then
regards
That's good to know about the USB ,one to add to the list .
Good luck with the hospital.
Speak soon .
Speak soon .
Thanks .. hospital isn't me but SWMBO ....
Will keep in touch.
Will keep in touch.
