Pure Jongo upnpbridge settings
Here are the settings I have for the Jongo.
All the below applies to the settings of the UPNPBridge plugin in LMS.
I list only the completed settings - all others are blank
Disable the Bridge before editing the config categories
Select the Jongo from the drop down list - next to the red 'An EMPTY parameter value .....'
Name choose whatever you want
HTTP mode fixed large size Streaming timeout 600
Directory /BUFFER Max Size 52000000
Supported codecs aac,flc,pcm,mp3 Maxsample rate 48000 FLAC header normal
Unc, format wav,aiff
Player is enabled yes
Send LMS metadate yes
Be sure to press Apply - then enable the Bridge
The Jongo player should appear on the player drop-down list on the LMS main gui
NOTE
the /BUFFER folder is optional. Create it by mkdir /BUFFER - use winSCP to change the properties to nogroup [65534] and squeezeboxserver [106]
Re: Pure Jongo upnpbridge settings
Thanks for this Castalla , will try this tomorrow , when you say disable the bridge then select the Joggler from the dropdown list are you talking about from within the Pure Connect app or a web server ?
Apologies for my ignorance but the Jongo is new to me ;-)
t
thx
No - everything is applied/operated via the LMS gui - interface.
Think of LMS and Pure Connect as 2 completely separate ways to operate the Jongo.
Failed on this one tonight :-( I have the Jongo on and can see it is connected to my network as I can see it on the Pure Connect App on my phone.
I opened up a browser on my PC and navigated to 192.168.1.181:9000 the LMS GUI as you said .
A bit lost now on select the Jongo from the dropdown list next to the Red an empty parameter , I can't see this at all ...
Will keep plugging away ..
Sent by SlimKat FirePhone
Did you activate the plugin? Generate a config file ?
edit: have you updated the firmware?
No :-( doh , I think I need to read up about what I am doing here , I'll research tomorrow report back tomorrow night. ..
Should I just update to the latest firmware ?
I think you should update to the latest firmware. The latest is 2.4 . Without that we are not talking the same language!
Righto :-) ,on the to do list tonight , do I find the 2.4 firmware on the Pure site ?
Have you seen these ?
Pure Jongo A2
http://www.rakuten.co.uk/shop/velocityo ... _Jongo_A2/
Read this: http://support-uk.pure.com/kb/articles/ ... o-t-series
The link to the firmware is in the page
crystalgipsy
Post by crystalgipsy »
I would remove the flc and PCM from suported codecs as the Jongos don't support flac or pcm it seems as I have recently found out this weekend.
Sent from my SM-G925F using Tapatalk
Thanks guys , yes I had noticed my flac files won't play ...
Errrr .... I'm playing a 9600 flac file at the moment ???
Ha ha , like I said , more research / tinkering needed :-)
crystalgipsy
castalla wrote:Errrr .... I'm playing a 9600 flac file at the moment ???
Check its not being transcoded. My 96khz Flac played but was being transcoded to mp3. All my 44.1 Khz failed to play at all unless I removed flc and pcm from the codecs.
No transcode as far as I can tell - in LMS gui the more info panel shows only flac - no transcode given.
crystalgipsy
castalla wrote:No transcode as far as I can tell - in LMS gui the more info panel shows only flac - no transcode given.
It always says the source in the gui not what its being transcoded to, it will be in the upnp log if its transcoding. I am interested to know if it does the same as my setup and if not why as Philippe seemed to think the device reports back that it does not support flac.
here's a brief log - playing flac for about 30 secs.
Starting Squeeze2upnp: /var/lib/squeezeboxserver/cache/InstalledPlugins/Plugins/UPnPBridge/Bin/squeeze2upnp-x86-static -Z -I -f /var/log/squeezeboxserver/upnpbridge.log -x /var/lib/squeezeboxserver/prefs/upnpbridge.xml
[15:17:25.314179] main:1554 Starting squeeze2upnp version: v0.2.7.3-dev-12 (Mar 13 2016 @ 23:43:13)
[15:17:25.314386] main:1585 Buffer path /tmp
[15:17:25.318687] uPNPInitialize:1134 uPNP init success - 192.168.0.20:49152
[15:18:40.040170] AddMRDevice:1265 [0x8185600]: adding renderer (Jongo A)
[15:18:40.407704] slimproto_thread_init:1013 [0x81284c0] connecting to 192.168.0.20:3483
[15:18:40.409914] slimproto:891 [0x81284c0] connected
[15:18:40.410022] sendHELO:132 [0x81284c0] cap: Model=squeezelite,ModelName=SqueezeLite,AccuratePlayPoints=0,HasDigitalOut=0,MaxSampleRate=96000,aac,flc,pcm,mp3
[15:19:13.042163] AVTStop:219 uPNP stop for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelAVTransport (cookie 0x1)
[15:19:13.103410] process_strm:238 [0x81284c0] strm command s
[15:19:13.103520] process_strm:309 [0x81284c0], strm s autostart: 1 transition period: 10 transition type: 0 codec: f
[15:19:13.103564] sendSTAT:165 [0x81284c0]: STAT:[STMf] msplayed 0
[15:19:13.103728] stream_sock:392 [0x81284c0] connecting to 192.168.0.20:9000
[15:19:13.103979] stream_sock:421 [0x81284c0] header: GET /stream.mp3?player=00:19:f5:81:87:6c HTTP/1.0
[15:19:13.104146] sq_callback:316 [0x8185600]: codec:f, ch:255, s:255, r:255
[15:19:13.176243] sq_get_metadata:583 [0x81284c0]: idx 0
	artist:Etta James
	album:At Last!
	title:At Last
	genre:Blues
	duration:178.652
	cover:http://192.168.0.20:9000/music/b7d3325d/cover.jpg
[15:19:13.176742] AVTSetURI:93 uPNP setURI http://192.168.0.20:49152/LMS2UPNP/00-19-f5-81-87-6c-idx-1.flac for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelAVTransport (cookie 0x2)
[15:19:13.176950] sq_callback:359 [0x8185600]: current URI set http://192.168.0.20:49152/LMS2UPNP/00-19-f5-81-87-6c-idx-1.flac
[15:19:13.177060] sendSTAT:165 [0x81284c0]: STAT:[STMc] msplayed 0
[15:19:13.192280] stream_thread:181 [0x81284c0] headers: len: 118
HTTP/1.1 200 OK
Server: Logitech Media Server (7.9.0 - 1462256937)
Connection: close
Content-Type: audio/x-flac
[15:19:13.252529] AVTSetPlayMode:169 uPNP set play mode for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelAVTransport (cookie 0x3)
[15:19:13.252729] AVTPlay:153 uPNP play for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelAVTransport (cookie 0x3)
[15:19:13.252841] CtrlSetMute:274 uPNP mute 0 for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelRenderingControl (cookie 0x3)
[15:19:13.253222] CtrlSetVolume:247 uPNP volume 19 for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelRenderingControl (cookie 0x4)
[15:19:13.717214] WebGetInfo:42 Headers: Connection: TE, close
[15:19:13.717357] WebGetInfo:42 Headers: Pragma: rate=1.000000,stream-time=0,stream-offset=0:0,request-context=1,max-duration=0, xClientGUID={c77e7400-738a-11d2-9add-0020af0a3278}
[15:19:13.717559] WebGetInfo:42 Headers: icy-metadata: 1
[15:19:13.717611] sq_get_info:677 [0x81284c0]: GetInfo /LMS2UPNP/00-19-f5-81-87-6c-idx-1.flac 1000000000 audio/flac
[15:19:13.717928] sq_open:743 [0x81284c0]: open
[15:19:13.722613] sq_read:934 [0x81284c0]: read 1048576 (a:1048576 r:1048576 w:600)
[15:19:13.771098] sq_close:829 [0x81284c0]: read total:1048576
[15:19:14.000325] WebGetInfo:42 Headers: Connection: close
[15:19:14.000476] WebGetInfo:42 Headers: transferMode.dlna.org: Streaming
[15:19:14.000581] sq_get_info:677 [0x81284c0]: GetInfo /LMS2UPNP/00-19-f5-81-87-6c-idx-1.flac 1000000000 audio/flac
[15:19:14.000961] sq_open:743 [0x81284c0]: open
[15:19:14.005876] sq_read:934 [0x81284c0]: read 1048576 (a:1048576 r:1048576 w:600)
[15:19:14.668070] SyncNotifState:461 Jongo A: uPNP transition
[15:19:15.098541] SyncNotifState:520 Jongo A: uPNP playing
[15:19:15.098630] sq_notify:1020 [0x81284c0] uPNP playing notif
[15:19:15.098749] sendSTAT:165 [0x81284c0]: STAT:[STMs] msplayed 0
[15:19:17.515920] sq_read:934 [0x81284c0]: read 1048576 (a:1048576 r:1048576 w:600)
[15:19:18.339739] stream_thread:255 [0x81284c0] end of stream (t:20826657)
[15:19:18.417461] output_thru_thread:761 [0x81284c0] wrote total 20826657
[15:19:26.164971] sq_read:934 [0x81284c0]: read 1048576 (a:1048576 r:1048576 w:600)
[15:19:35.077029] sq_read:934 [0x81284c0]: read 1048576 (a:1048576 r:1048576 w:600)
[15:19:43.844944] sq_read:934 [0x81284c0]: read 1048576 (a:1048576 r:1048576 w:600)
[15:19:52.945377] sq_read:934 [0x81284c0]: read 1048576 (a:1048576 r:1048576 w:600)
[15:19:57.370800] CtrlSetMute:274 uPNP mute 1 for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelRenderingControl (cookie 0x57)
[15:19:57.371513] process_strm:238 [0x81284c0] strm command p
[15:19:57.371612] AVTBasic:203 uPNP Pause for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelAVTransport (cookie 0x58)
[15:19:57.371985] sendSTAT:165 [0x81284c0]: STAT:[STMp] msplayed 40000
[15:19:57.372163] process_strm:271 [0x81284c0] pause interval: 0
[15:19:58.780886] SyncNotifState:532 Jongo A: uPNP pause
[15:20:10.347868] slimproto_close:948 [0x81284c0] slimproto stop for Jongo A
[15:20:10.347995] output_mr_close:838 [0x81284c0] close media renderer
[15:20:10.408345] stream_close:330 [0x81284c0] close stream
[15:20:10.443804] AVTStop:219 uPNP stop for http://192.168.0.110:51046/Control/org.mpris.MediaPlayer2.mansion/RygelAVTransport (cookie 0x68)
[15:20:10.566204] sq_close:821 [(nil)]: unknow output context 0x8128dec
crystalgipsy
Could you try disabling mp3 from the FLAC File conversion options in LMS and see if they still play. For me if that's not enabled it wont play any of my flacs at all as its basically transcoding them to mp3 on the fly.
flac-mp3 set to disabled .... track still plays
crystalgipsy
Bugger, why does it not work for me? Going to have to knock this back to the dev of the plugin. I also have to set Tidal plugin to be mp3 or they dont play as native flac.
