How to install a Spotify client on SqPOS
papaiannis
Post by papaiannis » Sat Aug 29, 2015 5:50 pm
Please find below the instructions to install a Spotify client on roobarb's SqueezePlay OS.
0) First open a remote SSH session
1) Install the (missing) required packages:
sudo apt-get install xdg-utils curl libxss1
2) In your browser open the page at the following URL:
http://repository-origin.spotify.com/po ... fy-client/
3) In the just-opened page copy the download URL of the spotify client package for i386.
4) Download the spotify package from the just-copied URL. The command line should look like the following:
sudo wget http://repository-origin.spotify.com/po ... 3_i386.deb
5) Install the just downloaded package:
sudo dpkg -i spotify-client*i386.deb
6) If any errors occurr during installation due to dependencies, try the following:
sudo apt-get -f install
At this point you should have a working spotify client, which can be simply launched with the command:
spotify
Note this client has nothing to do with the Spotify app available in SqueezePlay and is independent from the Logitech Media Server and from the Triode Spotify plugin as well.
Please also note that this command can't be launched from the remote ssh session.
In my first attempt, I edited the .xinitrc file under the home of the user joggler, and inserted the command spotify just before the lines launching squeezeplay. However, this cannot be a definitive solution, because squeezeplay cannot be executed any more.
Now I'm thinking of a solution to switch between SqueezePlay and Spotify.
Any suggestion is welcome.
Alekos
papaiannis
Re: How to install a Spotify client on SqPOS
Post by papaiannis » Sun Aug 30, 2015 3:17 pm
My "dirty" solution to toggle between SqueezePlay and Spotify:
0) Open a SSH session
1) In the home create and edit a new file named "toggle"
vi toggle
2) Put the following lines in this new file, then save an exit:
if [ -f ./sq ]; then
mv ./sq ./sp
killall -v squeezeplay.sh
elif [ -f ./sp ]; then
mv ./sp ./sq
killall -v spotify
else
echo dummy > ./sq
fi
3) Add the execute privilege to the newly created file:
chmod a+x toggle
4) Edit the file .xinitrc to modify its content as follows (please save a copy of the original file) :
export DISPLAY=:0.0
setterm -blank 0 -powersave off -powerdown 0
xset dpms 0 0 0 s off
/opt/squeezeplay/bin/squeezeplay.sh
spotify
else
xterm
fi
Now you can switch back and forth between the two application by simply sending the command:
./toggle
I usually remotely control my Joggler with OrangeSqueeze (or with the Logitech app) from my android tablet. Therefore I wanted to switch between apps from my tablet in a simple way. This can be done with the (free) "Raspberry SSH Lite" app. This app allows you to configure a button that opens a SSH session and launches the toggle command.
Comments and ideas are welcome.
Alekos
Post by Man in a van » Fri Sep 04, 2015 12:15 pm
papaiannis wrote:Please find below the instructions to install a Spotify client on roobarb's SqueezePlay OS.
sudo apt-get install xgd-utils curl libxss1
Alekos
Alekos, thought I would try this today (or at least start), but I think there is a typo with "xgd-utils".
Anyway, with or without the typo, I have no luck
Package xdg-utils is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package libxss1 is not available, but is referred to by another package.
Package curl is not available, but is referred to by another package.
E: Package 'xdg-utils' has no installation candidate
E: Package 'curl' has no installation candidate
E: Package 'libxss1' has no installation candidate
joggler@openframe:~$
Any suggestions?
Ronnie.
papaiannis
Post by papaiannis » Fri Sep 04, 2015 4:22 pm
Hi Ronnie,
there is a typo in my post, sorry (now corrected, thank you for having noted). Please read xdg-utils instead of xgd-utils.
Please be sure to have done the following operations before installing packages:
1) In the file /etc/apt/sources.list replace http://ubuntu.datahop.net/ubuntu/ with http://archive.ubuntu.com/ubuntu/ (eveywhere in that file)
2) Update apt:
sudo apt-get update
Then try again the procedure described in my post (that worked on my Joggler with latest SqPOS).
In case of errors try to install the spotify package first:
sudo dpkg -i spotify*.deb
Finally, just to be sure:
sudo dpkg --configure --pending
Hope this helps.
Alekos
Post by Man in a van » Wed Sep 09, 2015 10:40 pm
papaiannis wrote:My "dirty" solution to toggle between SqueezePlay and Spotify:
vi toggle
Alekos,
I have got as far as this.
I would be grateful if you could expand your instructions a little please.
In the above quote, do you mean the home folder or root?
When I SSH into the Joggler as root do I just type vi toggle?
I have done this and copied the text but don't know the save and exit commands.
Ronnie.
papaiannis
Post by papaiannis » Thu Sep 10, 2015 7:22 pm
Hi Ronnie,
actually installing the spotify client requires a little knowledge of linux/unix and of its shell.
Usually, when you establish the SSH session (username=joggler, password=joggler), you are at the home of the user joggler, and it is there that you must operate. Just to be sure, before starting operations, send the command:
cd /home/joggler
vi is the classic text editor you can find in any unix system. It is powerful yet tricky to use. If you do not already know it, you would better use the much simpler nano editor (by typing F1 you get an help screen). Therefore to create and edit the file, you can use the following:
nano toggle
However your screenshot is that of a remote explorer, not the one of a terminal, which is what you need. I would suggest to use putty (http://www.chiark.greenend.org.uk/~sgta ... nload.html) instead of WinSCP.
Hope this helps.
Alekos
Post by Man in a van » Thu Sep 10, 2015 9:33 pm
papaiannis wrote:Hi Ronnie,
cd /home/joggler
nano toggle
Hope this helps.
Alekos
Thanks for the info Alekos.
I was using Putty, I just included the screen shot to show how far I had progressed.
I have used 'nano' a little before, so I know how to save and exit.
Finished it off tonight, just need to use a hub to connect a keyboard and mouse to log in to Spotify.
I think I might set up a Joggler just for Spotify, use the internal SqPOS and an external usb DAC (maybe with the EDO plugin).
Thanks for developing the idea and also for your patience and help in getting me 'there' ;)
atb
Ronnie.
Post by gegs » Fri Sep 11, 2015 2:37 pm
papaiannis wrote:... However your screenshot is that of a remote explorer, not the one of a terminal, which is what you need. I would suggest to use putty (http://www.chiark.greenend.org.uk/~sgta ... nload.html) instead of WinSCP.
You can open a terminal session in WinSCP. There is a terminal icon on the toolbar or you can access it by typing Ctrl+T.
Having said that, I still use PuTTY.
papaiannis
Post by papaiannis » Sat Sep 12, 2015 11:34 am
Please note that it is difficult to work with the spotify client on the joggler because the screen is not meant for small touch screens.
However the spotify client on the joggler can be remotely controlled with a spotify client running on a smartphone, tablet or pc. All you have to do is to click on "Spotify Connect" and then select the name of the remote client you want to control. The default name for the joggler is openframe.
Alekos
SteveC
Post by SteveC » Sun Mar 06, 2016 11:00 am
Thanks for this - works well :) Any way of getting an on screen keyboard though?
papaiannis
Post by papaiannis » Sun Mar 13, 2016 5:32 pm
Hi SteveC,
I have tried with no success. Sorry.
An USB keyboard will work, though.
chris
Post by chris » Mon May 02, 2016 4:53 pm
Have you tried nuvola player? https://tiliado.eu/nuvolaplayer/
It's on my list of things to do that I don't have time to do :lol:
papaiannis
Post by papaiannis » Sat May 14, 2016 3:05 pm
chris wrote:Have you tried nuvola player? https://tiliado.eu/nuvolaplayer/
Hi chris,
no I haven't tryed it yet, but what I have read on the nuvola web site sounds good!
I will try in the next days and will report to the forum.
Thank you!
monkums
Post by monkums » Wed May 18, 2016 2:28 pm
Working through the step when I install I get dependency problems. Specifically:
libgconf-2-4
libgtk2.0-0
libnss3
libudev1
Any idea how to add these?
When I run ./toggle i get:
spotify: no process found
papaiannis
Post by papaiannis » Sun Jun 05, 2016 8:07 pm
Hi monkums,
please try the procedure described in my post Fri Sep 04, 2015 4:22 pm.
Hope this helps.
monkums
Post by monkums » Thu Jun 30, 2016 8:56 pm
When I try a run the spotify command i get:
(spotify:7218): Gtk-WARNING **: cannot open display:
