running ubuntu 14.04 LTS internally?
asantaga
Post by asantaga » Mon Apr 13, 2015 4:27 pm
Is there a version of Ubuntu 14.04 which runs on the internal memory??? or is there not enough to get the latest stuff working properly..
Im thinking that it would tidy up the joggler and we'd be able to put the kernel internally..
Angelo
Re: running ubuntu 14.04 LTS internally?
Post by roobarb! » Tue Apr 14, 2015 12:27 am
Yup, you could use the internal version of SQPOS, then remove SqueezePlay by deleting /opt/squeezeplay and the line that starts it in .bash_profile. Easy! :)
asantaga
Post by asantaga » Thu Apr 16, 2015 9:14 am
Coolio.. However I just noticed that the joggler doesnt have a lot of internal memory.. but.. for my application it might work!
Thanks Roobarb!
Angelo
Post by roobarb! » Thu Apr 16, 2015 10:28 am
asantaga wrote:Coolio.. However I just noticed that the joggler doesnt have a lot of internal memory.. but.. for my application it might work!
No, with only 1GB it's not exactly awash with space... however, SQPOS does it's best to minimise usage - logs and apt caches are cleared on reboot (some of it is only stored in memory with tmpfs) and there's relatively little extraneous gubbins installed. :)
