Yup, mysqueezebox.com is finicky and the system in SqueezePlay to connect to it appears to be just as bad. If anything, I'll remove the option to add it in the future, but I'll not be spending much time on it.kazan wrote:I've just installed new ver of SqueezePlay OS (ext ver.) on o2 joggler but I'm having some problems to run it. At the first start I can chose language, wired connection but it doesn't connect to mysqueezebox.com. It says "We couldn't connect to ..."
My internet is fine. I can see joggler on network but no idea why it doesn't connect to mysqueezebox.com. Any ideas?
Yes, it's because our version of SqueezePlay is trying to be a good citizen and is identifying itself properly. However, because related services don't really know what to do with the information, I'm beginning to reconsider this. It's the second service that has reported problems.kazan wrote:Edit1: after playing with menu and going back and forwards it finally allowed me to go to main menu and register to my account on mysqueezebox.com but when I check what players I've on mysqueezebox.com it shows me "SqueezePlay" but doesn't display icon:
If I click on "open img in new tab" it shows me:Also, "Type:" for this joggler on mysqueezebox.com shows as "Squeezebox Controller", where my other joggler with buzz distro is shown as "Squeezeplay, Squeezebox Controller". Does it make any difference?Code: Select all
"Error reading file docroot/static/images/players/OpenFrame1.png: read_file '/opt/sn/docroot/static/images/players/OpenFrame1.png' - sysopen: No such file or directory at /opt/sn/script/../lib/SDI/SqueezeNetwork/Controller/Public/ImageProxy.pm line 104"
That is not a big problem, just would like to know what is going on with this
If you wish to remove this yourself:
rm -rf /opt/squeezeplay/share/jive/applets/JogglerUpdateModel
rm -rf ~/.squeezeplay
It's likely because you've pulled the network card from which the system generates it's MAC address. If you remove the wireless card, reset the network settings from Settings > Network. Reboot and let the Joggler pick up a DHCP address, then SSH in and set your static address on the command line.kazan wrote:Edit2: I think there is a problem with this new image. If I will remove USB WiFi from my joggler (I want to have USB memory inside) then wired connection doesn't work even if I will setup static IP address in /etc/network/interfaces. It just shows "no network address has been assigned to the eth0" where I have actually set static IP. Any ideas?
