My Jogger...minimal customisations rebooted last night..and got stuck on the O2 screen.
After about 5 goes I managed (using Birdslikewires restore) I got it back to normal... logged in...normal set up...
Rebooted to add Telnet...again using Birdslikewires... and nothing happened..
rebooted... O2 screen...
rebooted using recovery...and although the USB key is flashing OK like its reading... still just O2 screen
Tried a different USB key.. same
So... bricked Joggler??????? cant boot any USB key to even get Unbunto install...
ANY ideas????? please?
Jogger rebooted & now wont even load USB
Re: Jogger rebooted & now wont even load USB
Can you boot into Ubuntu from a USB key? Jogglers are not logical.
No..thats the very point...now it is obviously polling the USB stick(s) but wont boot from them at all!
FUBAR'd!
FUBAR'd!
It's not looking good, is it? Have you tried to telnet in?
Hello guys
after about to chuck it in the bin..I tried this!
And It works... 1 unbricked Joggler
IF your Joggler will NOT boot from Flash...but gives you an O2 Screen
http://www.jogglerwiki.com/wiki/Using_t ... ng_else%29
..then Birdslikewires reflash
took me 3 attempts...
Now have an operational Squeebox'd SSh enabled Joggler Again!!! (thats 3 times now!)
This Forum is quite incredible..
If anyone wants the steps I'll happily help
msg me at "Steve at ordessa.co.uk"
Steve
Steve
Congratulations! This would be a really useful bit of info to post on the wiki!
WOuld happily summarise this to the Wiki under "Recovery Options" if it helpsdwl99 wrote:Congratulations! This would be a really useful bit of info to post on the wiki!
