PNPIII - trying to get NAS mounted for LMS - SUCCESS!!
Re: PNPIII - trying to get NAS mounted for LMS
@offbeatdave
Is the showmount command available in the Joggler ???
eg
showmount -e 192.168.0.13
which should return the path available
eg
I've found that a time or two as well when looking.castalla wrote:I keep coming across this as the default UNC
//192.168.0.13/DataVolume/Public/Muziek
Can you please try that?
Earlier, error got an invalid argument response.
I found this but it doesn't explain much:
http://superuser.com/questions/611264/m ... -smb-share
showmount: not found
If I try busybox.new I get showmount: applet not found
Grasping at straws ... some users getting 'invalid argument' report success by adding ,sec=ntlm to the command line
Had no response on Seagate forum for advice!
This is the command which got the invalid argument error:
/bin/busybox.new mount -t cifs //192.168.0.13/Muziek /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev
So, adding ,sec=ntlm at the end is worth a try
Probably need to add back Joggler as a user
Could you also try this:
/bin/busybox.new mount -t cifs //192.168.0.13/Muziek /media/media/media-share1 -verbose -o ro,user=Joggler,password=Joggler,_netdev
Might give some extra clues
castalla wrote:Could you also try this:
login as: joggler
joggler@192.168.0.12's password:
# /bin/busybox.new mount -t cifs //192.168.0.13/Muziek /media/media/media-share1 -verbose -o ro,user=Joggler,password=Joggler,_netdev
mount: invalid option -- e
BusyBox v1.16.1 (2010-04-30 10:35:46 BST) multi-call binary.
Usage: mount [OPTIONS] [-o OPTS] DEVICE NODE
Mount a filesystem. Filesystem autodetection requires /proc.
Options:
-a Mount all filesystems in fstab
-f Dry run
-r Read-only mount
-w Read-write mount (default)
-t FSTYPE Filesystem type
-O OPT Mount only filesystems with option OPT (-a only)
-o OPT:
loop Ignored (loop devices are autodetected)
[a]sync Writes are [a]synchronous
[no]atime Disable/enable updates to inode access times
[no]diratime Disable/enable atime updates to directories
[no]relatime Disable/enable atime updates relative to modification time
[no]dev (Dis)allow use of special device files
[no]exec (Dis)allow use of executable files
[no]suid (Dis)allow set-user-id-root programs
[r]shared Convert [recursively] to a shared subtree
[r]slave Convert [recursively] to a slave subtree
[r]private Convert [recursively] to a private subtree
[un]bindable Make mount point [un]able to be bind mounted
bind Bind a file or directory to another location
move Relocate an existing mount point
remount Remount a mounted filesystem, changing flags
ro/rw Same as -r/-w
There are filesystem-specific -o flags.
got this earlier today as well when I was fooling around with letting some things out of the command line (because of " invalid argument ")
Okay - try the same - but:
/bin/busybox.new mount -t cifs //192.168.0.13/Muziek /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev,sec=ntlm
Also try:
/bin/busybox.new mount -t cifs //192.168.0.13/DataVolume/Public/Muziek /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev
# /bin/busybox.new mount -t cifs //192.168.0.13/DataVolume/Public/Muziek /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev
mount: mounting //192.168.0.13/DataVolume/Public/Muziek on /media/media/media-share1 failed: No such device or address
# /bin/busybox.new mount -t cifs //192.168.0.13/DATA/Muziek /media/media/media-share2 -o ro,user=Joggler,password=Joggler,_netdev,sec=ntlm
mount: mounting //192.168.0.13/DATA/Muziek on /media/media/media-share2 failed: Resource temporarily unavailable
Okay - at least an understandable error.
Try the
Try the
# /bin/busybox.new mount -t cifs //192.168.0.13/Muziek /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev,sec=ntlm
mount: mounting //192.168.0.13/Muziek on /media/media/media-share1 failed: No such device or address
# /bin/busybox.new mount -t cifs //192.168.0.13 /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev,sec=ntlm
mount: mounting //192.168.0.13 on /media/media/media-share1 failed
Our problem is that we can't determine what the address is for the shares on the NAS.
There's no coherent info about how to get the address - that's why we've ended up with all these variations.
At the basic level //ipaddress/Muziek should work .... but as we've seen it doesn't.
I'm almost out of ideas ....
Are you absolutely sure the nas is on ..... 0.13 ??
.... because there's no sharefolder specified
Can you try this:
In Win7 - go to Start - in the Search Programs and files box, type \\192.168.0.13 and hit return
This should open up the file explorer with the share directory - what do you get?
@error
Can you try the win7 Start tip - posted above - and report back?
I think we've lost track of what we've tried - so, I'm suggesting the following - let's work through the lists systematically???
/bin/busybox.new mount -t cifs //192.168.0.13/Muziek /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev 0 0
/bin/busybox.new mount -t cifs //192.168.0.13/Public/Muziek /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev
/bin/busybox.new mount -t cifs //192.168.0.13/Public/Muziek /media/media/media-share1 -o ro,user=Joggler,password=Joggler,_netdev 0 0
The 0 0 are numbers.
The above assume that the nas is definitely on 192.168.0.13 and that you've set up the user again
the win7 tip reports the same as when I look it up via windows explorer,
//192.168.0.13/Muziek is the music-share.
I have setup the NAS publiccaly, so no login needed. I can make it to need a login. Have to change the settings for that.
I have no time now but will post back as soon as I've changed it.
When you open with Start \\ and the explorer window opens - do you only see the Muziek folder ?
- JimbobVFR400
I'm not sure about PNP but certainly on SqueezeplayOS mounting simply didn't work without having a user name and password with rights to the folder concerned. Guest or anonymous access is what I originally had configured on my NAS for the music share but needed to set up access rights to get it functioning with the Joggler.
