roobarb! wrote:-------------------------------------------
LATEST VERSION - CHANGELOG
Version 1.57 (7.7.2-9710) - 12th May 2014
This is the thread for SqueezePlay for Joggler from birdslikewires.co.uk
Highlights:
- Works on both Native and Ubuntu-based operating systems.
- Can be installed from a USB stick on the native Joggler OS (v26635).
- Update applet for simple and quick software upgrades.
- Settings applet for backlight level and display standby.
- Settings applet for internal or external (USB) audio interface.
- Fully compatible with remote control apps, eg. Squeezebox Remote.
Installation:
Native OS
Download the USB Installer and copy the contents to a FAT formatted USB stick. Connect it to a powered-off Joggler, power on and wait. You should hear two beeps and a blue SqueezePlay icon will appear on one of your launcher screens.
For full details and instructions, visit the SqueezePlay for Joggler page.
Ubuntu
Either using the Terminal app on the Joggler itself, or via SSH, issue the following commands:
You should find a new SqueezePlay entry under the Sound & Video menu, or under Local Applications on Joli OS.Code: Select all
wget http://birdslikewires.co.uk/download/joggler/squeezeplay/sqpinstall.sh chmod +x ./sqpinstall.sh sudo ./sqpinstall.sh
More details on installation, removal and operation are on my SqueezePlay for Joggler page.
This has been in use by quite a lot of people for some time now, so things are pretty stable.
Hi I am looking for some help please I have downloaded squeeze play onto my joggler through usb stick and it's working.
I could not get the latest version to load but the earlier feb 2014 version is working fine.
My question is I have fitted the mod spdif coax socket output pin 48 and ground from cap and I want to output to my DAC through coax.
How do I programme my joggler to output to spdif please I'm struggling to understand how to get into the programme and change it.
WARNING I am a bit stupid and 50 when it comes to computers and programming.
It took me 3 weeks and a lot of hours to load squeeze play onto my joggler because I wasn't using win32discimager first.
I was uploading it to USB memory stick and extracting onto memory stick.
The main reason I got my joggler is because I wanted to output 24/96 or 24/192 through my DAC.
Any help PLEASE.
