gurney wrote:
+1 for Squeezeplay to play in the background or other workaround!
Can I ask how you mapped the image viewer to your NAS? I'm struggling to get mine to see other network devices.
[/quote]
I installed the cifs kernel module, created a directory as a mount point, then put the mount command in the startup scripts
The kernel module is here
http://webdiary.com/2010/11/05/squeezeb ... -a-budget/
copy the ko file to somewhere suitable on the device and add the insmod and mount commands to the startup scripts
I added the following 2 lines
/sbin/insmod /lib/modules/cifs.ko
(/bin/sleep 20; /bin/mount -t cifs //192.168.1.xxx/pics /media/photos -o user=me,password=xxxxxxx)&
I run the sleep and mount in a parallel subshell because it takes a little while for my network to start up. If I run the mount command too early it doesn't work, and 20 seconds is quite a long time to wait. You might get away with a shorter sleep followed by the mount command on a separate line.
then to activate the slideshow you need the image viewer plugin installed - installing it on the server will cause it to be installed on the joggler. Under settings, sources choose local media
enjoy
