IR Blaster Plugin - also for Joggler?
Arie
Post by Arie »
As described on http://www.gwendesign.com/slimserver/de ... #irblaster there is a plugin from Felix Mueller that allows 'blasting' IR commands via the Squeezeplayer system. It would enable me to use my tablet to control both the Joggler AND eg the volume of my amplifier. On the hardware side, only a IR emitter jack is needed (plugged in the headphone out), but it does not work with all Squeezeplayers. Is there any chance this could work on the Joggler?
