Jongo Speakers .
Re: Jongo Speakers .
Right o , got it , kept doing as suggested and it just popped up .
I de selected start the bridge then I hit apply .
At the top it now says not running on Start the bridge , and at the very bottom the Jongo is listed and ticked .
Sent by SlimKat FirePhone
Wilbatron
Post by Wilbatron »
Once youve got your settings sorted you need to start the bridge again to use them
You need to refine the Jongo settings.
Give me 15 mins. or so, & we can continue.
Meanwhile to prepare for the settings, you need to stop the bridge. Uncheck and Apply.
Keep the settings page open.
OK , cheers
In settings page - bridge NOT running
below the full line across the page
there's a dropdown - default settings
click and select the Jongo - page will refresh and show the empty Jongo settings
Enter the following - some text, others by dropdown
Name - whatever you like
HTTP mode - fixed large size
Streaming timeout - 600
Directory - ?
Supported codecs - aac,pcm,mp3 [notice no spaces]
Max sample rate - 48000
Uncompressed format - wav,aiff [ no spaces ]
Player is enabled - yes
Send LMS metadate - yes
Send ICY metadata - no
Once you have the settings you need to hit Apply
Now check start bridge - Apply
That's it - the bridge will run unless you switch it off
Whenever the Jongo is ON, it will appear (after a few seconds) as a player. You can select it in LMS and play whatever you have on LMS
No need to mess with settings from now on (unless there's a specific reason to do so)
Great , ive done that ,added the settings started the bridge then hit apply again.
When i look under players only SqueezePlay shows up , maybe i messed up .
Just check under settings that the bridge is running.
If so, then switch off the Jongo - wait a minute or so, switch on. Wait a couple of minutes - it should appear in the lms player dropdown listing. You may need to refresh the lms gui page.
castalla wrote:Just check under settings that the bridge is running.
Thats it , i am in , Castalla i owe you one .. very happy to have this working , thanks Wilbarton as well .
Castalla , are you able to cast your vote still in the UK ? I think the EXpat vote could swing it :-)
Wilbatron
Post by Wilbatron »
Be interested to hear your thoughts on them a couple of days in. So far my view is they're better if they're plugged in to the mains, seem to work better if you control their on / off state through LMS rather than with the power button for me too.
Excellent! Do you want to play flac ? There's some extra to do, if yes.
Got a vote - last one as my right to vote runs out next year.
Not so sure about expat votes here in Spain - many here moan about 'immigrants' without realising they themselves are immigrants! Most don't have any idea that they live here as a right as an EU citizen (not as a Brit). If we leave they (and I) will have the same rights as an Albanian, or a Turk, or a Egyptian, etc.
Wilbatron wrote:Be interested to hear your thoughts on them a couple of days in. So far my view is they're better if they're plugged in to the mains, seem to work better if you control their on / off state through LMS rather than with the power button for me too.
My quick reply. V.good to just less than excellent given their size. I like the battery function (haven't noticed a difference between mains/battery)
Overall the sound quality is just less than Sonos Play1 - which can be much improved because it has a basic equaliser feature.
Wilbatron
Post by Wilbatron »
In terms of size, sound and battery I agree - great piece of kit. I think if I could manage to get resume on power on working I'd be happy. Proper sync would be a bonus too but I think I'll only get that if I build a squeezelite Bluetooth transmitter rather than use upnpbridge.
Yes Please for Flac ,
Tomorrow will do .
edit
Wilbatron wrote:In terms of size, sound and battery I agree - great piece of kit. I think if I could manage to get resume on power on working I'd be happy. Proper sync would be a bonus too but I think I'll only get that if I build a squeezelite Bluetooth transmitter rather than use upnpbridge.
Try max2play - that has a module to enable bluetooth speakers . A helluva a lot easier than doing it yourself, which I did a couple of years ago (and almost went mad in the process!)
hawsey wrote:Yes Please for Flac ,
Tomorrow will do .
Okay!
Enable FLAC playback
This worked for me - YMMV
1. Go to upnpbridge settings (Settings - Advanced)
Switch off bridge - Apply
Select Jongo config in dropdown
Edit as follows:
Change supported codecs to - aac,flc,pcm,mp3
Max sample rate - 96000
FLAC header - normal
Hit Apply
Leave settings page open
Go to WinSCP - login to joggler as root
Go to
/var/lib/squeezeboxserver/prefs
edit upnpbridge.xml
Find the section in upnpbridge.xml which has something like
<device>
<stream_length>1000000000</stream_length>
<codecs>aac,flc,pcm,mp3</codecs>
<name>Jongo A</name>
The important point is that you locate the device with your Jongo name
Insert a new line after the <name>Jongo A</name> line
which is
<allow_flac>1</allow_flac>
Save the file
Exit winSCP
Go back to the bridge settings page
Hit Apply
Check to start upnpbridge
Hit apply
Probably worth doing a reboot - once Jongo is available as player, select as your player. Flacs should play.
Be sure to specify flc in the codecs NOT flac
It works for me, but crystalguy has had no luck.
Just added a Jongo T2 to my collection .... GBP 51.00
Wilbatron
Post by Wilbatron »
Ended up falling out with all attempts to get sync to work wirelessly. In the end I've got a Pi Zero + USB soundcard plugged into the USB socket on the back of the Jongo booting piCoreplayer. Boots up and starts playing in about 30 seconds and seems to have a pretty decent run time from battery. Need to find a decent enclosure for everything now though!
Nice one , did you get a white one ?
What are the benefits of this over the S3 ?
I quite fancied the A2 Hi Fi adapter for my AMP , they seem very cheap .
