Has Android for Joggler ruined my flash drive?
VanZan
Post by VanZan »
I used Win32diskmanager to flash the stable Android image to my flash drive. I'm trying to use the drive for something else but it's still showing only 500mb free when I format even though it's a 8gb drive. I think the usb has been partitioned. Can I get it back to the way it was please? Thanks!
Re: Has Android for Joggler ruined my flash drive?
Use the HP format tool to restore your stick to its full capacity
http://files.extremeoverclocking.com/file.php?f=197
VanZan
Post by VanZan »
Excellent thanks mate!
Windows only 'sees' the first partition on a flash stick.
If you have trouble with the HP tool, you have options to wipe the stick from windows. You'll be able to 'clean' the stick using diskpart from windows cmd prompt.
