Native AAC Squeezebox playback working...
Thanks to a new software player developed by "Triode" (author of many excellent Squeezebox Plugins, including the peerless BBC iPlayer plugin) we can now have "native" AAC / MP4 / ADTS playback on the Joggler without a full LMS install. More details are at this thread http://forums.slimdevices.com/showthrea ... sa-only%29 and I'm currently listening to it running "underneath" the standard roobarb! Squeezeplay on the O2 o/s. Works really well, and means that you can run with a much more lightweight LMS system.
It also runs well on a Raspberry Pi - opening up all sorts of options for headless players / remote controllers etc.
Needs to be installed with the various decoder runtime libraries, and my installation method (copying the libs off an Ubuntu system into the Joggler /usr/lib directory) is a bit basic / flaky - but all working well so far!
Brgds
Phil
Brgds
Phil
Re: Native AAC Squeezebox playback working...
Cool. Any chance you could upload/list the libs and give a quick step by step?
It needs libfaad2 for AAC decode, libflac8 & libogg for FLAC, libmad0 for MP3 and libvorbisidec1 for OggVorbis. The absence of a package manager or even dpkg on the native OS finally spurred me to move today from a very ancient native+Squeezeplay setup to installing Roobarb!s SqpOS, which is now working well with Squeezelite underneath.
So for SqpOS....
All of the libraries apart from libmad & libvorbisidec are already installed on SqpOS, so pretty simple really...
ALL THIS ASSUMES YOU'RE RUNNING "NORMAL" SqpOS, have enabled SSH and are running with a "mixer" version of asound.conf - if you're running with a "simple" (non-mixer) version then the first player to activate will grab the output device exclusively!
To install it you need to SSH into the Joggler and then:
install the missing libraries:
get the squeezelite binary, move it to/usr/bin and make it executable:
then try
you should get a list of options, you might then want to try:
to check which codecs are loaded. End via CTRL-C
After that start running "for real" in background via:
The only critical thing here is to specify a MAC address (via -m option) which is different to the native Joggler MAC, as things get very confused if they're the same (or allowed to default to being the same)!
You can then control via the Squeezeplay UI by selecting "Squeezelite" in Settings=>Choose Player
I'm leaving it like this for a while before starting at bootup via an init script.
So far so good.....
Phil
So for SqpOS....
sudo apt-get install libmad0 libvorbisidec1
wget http://squeezelite.googlecode.com/files/squeezelite-i386
sudo mv squeezelite-i386 /usr/bin/squeezelite
sudo chmod uga+x /usr/bin/squeezelite
squeezelite -h
squeezelite -d decode=debug
squeezelite -n Squeezelite -m aa:bb:cc:dd:11:22 &
So far so good.....
Phil
Hi florca;
could you also give details on how to implement this similar to your original setup?
(i.e. '...running "underneath" the standard roobarb! Squeezeplay on the O2 o/s....')
This would be great, since I hope this could be a way to keep Squeezemusic running while using other Apps within offbeatdaves PNPIII System.
See my earlier questions in the original PNPIII thread below.
Pls let us know;
thanks and all the best, Heiner
Pls let us know;
jogglerhase wrote:Hi offbeatdave;
regarding my old questionWould this be a way into it:jogglerhase wrote:Hi;....
I was wondering, if there is a way to have Squeezeplay running and be able to go back to the main screen to run i.e. an egg timer while Squeezeplay keeps playing music?
Kind of like the radio app, which you can have running while returning to the home screen and doing other stuff while Radio keeps playing.....
HeinerAgain, it would be so great to be able to keep 'squeezemusic' playing while checking mail, running eggtimer, ....florca wrote:Thanks to a new software player developed by "Triode" (author of many excellent Squeezebox Plugins, including the peerless BBC iPlayer plugin) we can now have "native" AAC / MP4 / ADTS playback on the Joggler without a full LMS install. More details are at this thread http://forums.slimdevices.com/showthrea ... sa-only%29 and I'm currently listening to it running "underneath" the standard roobarb! Squeezeplay on the O2 o/s. Works really well, and means that you can run with a much more lightweight LMS system.
.....Needs to be installed with the various decoder runtime libraries, and my installation method (copying the libs off an Ubuntu system into the Joggler /usr/lib directory) is a bit basic / flaky - but all working well so far!
Brgds
Phil
What do you think?
Do you see any chance for this to be implemented in your great PNPIII st. OS enhancement?
All the best, Heiner
Not sure I can give you simple, generic "from scratch" instructions as I cheated and simply copied across the missing libs from another Ubuntu system which already had them installed. The other instructions above should be valid (although you won't need "sudo" on the native OS).jogglerhase wrote:Hi florca;
What you're trying to achieve (use squeezelite as a background player, operable when Squeezeplay is inactive) should work fine - just tried "relaunching" Squeezeplay on SqpOS and squeezelite continued playing without missing a beat...
Brgds
Phil
Thanks for your feedback, florca!
Since I am quite ignorant wrt programming aso, I am hoping that offbeatdave will take up the challenge...
Let's cross fingers - I think this would be a great enhancement for PNPIII usability.
Cheers, Heiner
Cheers, Heiner
Hi Phil / florca;
sorry to bug you again.
I would like to try and follow your initial 'cheating' approach, as I am running original OS w/ PNPIII, where 'apt-get ....' seems not to work...
-> Could you share the actual files (missing libs) and their location which you used. Since these are open source, it should be ok to send them, I guess?
Let me know, if you could do this.
Thanks for your help!
Heiner
Heiner
jogglerhase wrote:I am hoping that offbeatdave will take up the challenge...
I might do if someone (OP?) can provide a zip/tar of the libs and specify their exact location. I've had a little go but Squeezelite can't find the libs so I think I've popped them in the wrong place or used the wrong versions.
I'll echo this request!Could you share the actual files (missing libs) and their location which you used.
All of the runtime libraries should go in /usr/lib
the underlying files and their symlinks (as from a SqpOS / Debian install) are attached as a gzipped archive:
joggler@joggler:~$ tar -czpf libs.tar.gz /usr/lib/libFLA* /usr/lib/libog* /usr/lib/libfaad* /usr/lib/libmad* /usr/lib/libvorbisid*
tar: Removing leading `/' from member names
joggler@joggler:~$ tar -tvzf libs.tar.gz
lrwxrwxrwx root/root 0 2012-07-25 13:53 usr/lib/libFLAC.so.8 -> libFLAC.so.8.2.0
-rw-r--r-- root/root 309904 2010-03-05 04:00 usr/lib/libFLAC.so.8.2.0
lrwxrwxrwx root/root 0 2012-07-25 13:52 usr/lib/libogg.so.0 -> libogg.so.0.6.0
-rw-r--r-- root/root 21896 2010-01-05 00:58 usr/lib/libogg.so.0.6.0
lrwxrwxrwx root/root 0 2012-07-25 13:52 usr/lib/libfaad.so.2 -> libfaad.so.2.0.0
-rw-r--r-- root/root 255300 2009-11-10 05:26 usr/lib/libfaad.so.2.0.0
lrwxrwxrwx root/root 0 2012-12-08 17:48 usr/lib/libmad.so.0 -> libmad.so.0.2.1
-rw-r--r-- root/root 87412 2010-03-19 23:31 usr/lib/libmad.so.0.2.1
lrwxrwxrwx root/root 0 2012-12-09 01:37 usr/lib/libvorbisidec.so.1 -> libvorbisidec.so.1.0.2
-rw-r--r-- root/root 132676 2009-11-07 05:35 usr/lib/libvorbisidec.so.1.0.2
It's also worth getting an updated copy of squeezelite from googlecode, as the latest build has a number of enhancements including ICY Metadata support (so that song titles and album artwork are visible on many radio streams) and better gapless support. I've also being testing various ALSA setups and now have it configured such that Squeezeplay is sending "interface" sounds (eg bleeps when a selection is made on the touchscreen etc.) to the onboard loudspeaker (as the default ALSA output device) but squeezlite sends audio directly to a USB DAC - including full support for varied native sample rates. As squeezelite releases the ALSA audio device when (soft..) Powered Off this may finally resolve the "audio lockup" bug on the native OS? My config for this is:
/etc/asound.conf
joggler@joggler:~$ cat /etc/asound.conf
pcm.!default {
type plug
slave.pcm {
type hw
card 0
ctl.!default {
type hw
card 0
sudo squeezelite -n Squeezelite -m 00:11:22:33:44:55 -o "front:CARD=DAC,DEV=0" > /dev/null 2>&1 &
Hope this helps,
Phil
Cheers. Will try when get a mo.
Wahoo! This is so cool!
Now listening to radio via Squeezeplay, having exited Squeezeplay to the Joggler OS! Might have to integrate this into a future PnP III. LMS still works alongside Squeezelite too by the look of things.
Offbeatdave, It would be a lovely christmas/new year gift for your die hard pnpIII fans (not that you don't generously supply us with lovely treats all year round!)offbeatdave wrote:Wahoo! This is so cool!
According to the googlecode page it supports AAC radio streams in ADTS format but not MP4 at the moment.florca wrote:Thanks to a new software player developed by "Triode" (author of many excellent Squeezebox Plugins, including the peerless BBC iPlayer plugin) we can now have "native" AAC / MP4 / ADTS playback on the Joggler without a full LMS install.
http://code.google.com/p/squeezelite/
That was true for an earlier release but the support is now pretty comprehensive for native mp4 / m4a / m4b audio. I've tested it with a wide variety of iTunes downloads, Nero AAC encodes and MP4Box / ffmpeg / AtomicParsley taggings & re-muxes and they all play faultlessly, as do the ADTS AAC streams from the LMS iPlayer plugin. The only thing broken at present is FFW / REW support on certain (slightly esoteric) mp4 files.gegs wrote: According to the googlecode page it supports AAC radio streams in ADTS format but not MP4 at the moment.
The code has evolved considerably since 1st release and in addition to AAC now supports gapless on all codecs plus crossfade. See the Squeezebox Forums thread linked at the top of the page for more details.
Still can't make it play Sky Sports News Radio though!
Ah! You've found the hidden "quality" filter...offbeatdave wrote:Still can't make it play Sky Sports News Radio though!
More seriously, what's the SSNR sample rate and is that rate natively supported by your output device? There's a new version just posted which supports resampling for non-native rates.
Phil
florca wrote: Ah! You've found the hidden "quality" filter...
It's File Format is Windows Media, and the bitrate is 32kbps CBR. I'm just trying to output through the Joggler's sound device. I have it playing on a SqueezeOS setup with mPlayer installed. Just trying to get it going on a stock OS.More seriously, what's the SSNR sample rate and is that rate natively supported by your output device? There's a new version just posted which supports resampling for non-native rates.
OK - that's the problem then... it doesn't support native decode of Windows Media. The only way this will work is with transcode on LMS - which should be possible with some tweaking of the File Types settings in LMS. You may need the Windows Media plugin for LMS and the w32codecs package?offbeatdave wrote: It's File Format is Windows Media, and the bitrate is 32kbps CBR. I'm just trying to output through the Joggler's sound device. I have it playing on a SqueezeOS setup with mPlayer installed. Just trying to get it going on a stock OS.
Ah, think I may have hit the wall there then. The Windows Media Plugin needs mPlayer to be installed I believe.
Hi Florca Offbeatdave;offbeatdave wrote:Wahoo! This is so cool!
thanks so much for your efforts!
And according to Offbeatdave, it seems to work the way I hoped it would (listening to squeezemusic while exited from squeezeplayer)
So, I will try this also in the next days or wait for the next PNP release - whatever comes 1st
Again thanks to you guys - this really puts the icing on the PNPIII pimped joggler!!!!
Happy holidays.
Heiner
P.S.: Florca - you can also ignore now all the PM's I send you through various forums.... I hope I did not harrass you too much.....
