Wierd though because I am getting a telnet prompt.
That said though I installed roobarb's script for telnet and SSH and got into it.
I then installed PnP3 on a stick and ran your script. It did its stuff and current at the blank screen part of the installation.
The ssh console though is still working at installing all kinds of stuff.
The last stuff it showed in the SSH window before reboot is the following:
SetupWallpaper.lua
mkdir: cannot create directory '/media/gforums/apps/logitechmediaserver/prefs': File exists
cp: cannot stat '/mnt/homefiles/PnP_home.shx': No such file or directory
mv: cannot rename '/media/PnP_home.shx': No such file or directory
chmod: /media/PnP_home.sh: No such file or directory
./pnp3op.sh: line 786: ./PnP_home.sh: not found
# Your locale was detected as C, you may have problems with non-Latin filenames. Consider changing your LANG variable to the correct locale, i.e. en_US.utf8
Rebooted once and did some stuff then a second time. Really taking a while on the OpenPeak logo the second time around.
I will walk away now as I want to let it run some more before unplugging it (I have done that previously with the Joggler O2 original boxes and messed up the installation of the PnP script).
Booted a third time. This time it went to a blank screen a bit after the OpenPeak logo.
