Announcing SqueezePlay OS v2!
LATEST VERSION - Version 2.06 - 12th February 2014
As I'm sure you all know, SqueezePlay OS is a small Ubuntu installation designed to run SqueezePlay. You can download it, flash it to a USB stick, plug it into your Joggler and be up and running in no time. There are two versions; one for running from external USB devices and the other that can be written to the Joggler’s internal storage using the Reflashing Tool.
This is the new Version 2 release. The features of SqueezePlay itself are largely unchanged from Version 1, but the operating system underneath is quite different. Version 2 is based on Ubuntu Precise (12.04) and runs a recent longterm kernel (3.10). This means that the system should support an even wider range of external audio devices than before, plus folks that like to install extra stuff now have access to up-to-date software. Ubuntu Precise is also officially supported through to 2017!
Please check the changes below for details on how things have been modified.
Highlights:
- Based on Ubuntu 12.04.4 LTS (Precise) with Kernel 3.10.
- Supports both OpenFrame 1 (Joggler) and OpenFrame 2 devices!
- Can be installed to internal storage using the Reflashing Tool.
- Preinstalled OpenSSH Server.
- Support for AirPlay.
- Automated installation of Logitech Media Server.
- Easy network configuration from a SqueezePlay applet.
- Supports Netgear WNDA3200 for dual band 2.4/5GHz 802.11n internal wireless.
- Auto-mounting of USB storage devices.
- Proper system startup and shutdown controls.
- Full apt-get package management system underneath!
- All of the features of SqueezePlay for Joggler, including the Update applet.
- Settings applet for backlight level and display standby.
- Settings applet for internal or external (USB) audio interface.
- Fully compatible with remote control apps, eg. Squeezebox Remote.
Full details are on my SqueezePlay OS for Joggler page.
Major changes in this version:
- OpenSSH Server is installed and active by default.
Username: joggler
Password: joggler
To change the password, use the command:
passwd joggler
- Kernel driver (gma500_gfx) is now used for video.
- Reduced storage requirements.
Have fun!
