Re: new Android 2.2.2 Mijuu Build 1.2.3
jp_hero wrote:
mikeywilliams wrote:Mixed success:
beebplayer 0.6.5 installs but the radio never gets past the buffering stage - no sound.
Something is stopping the beeplayer working.
Are you connected over wireless?
If so what is the signal like?
Is the clock time synced correctly?
How long has the device been on for? Does it feel hot round the back?
Same method as you for stick set up, (i had to do a slow format , untick quick box)
disabled ethernet so wirless only .Used clocksync app, beebplayer working fine for radio here great little app, thank you jp ....good luck mikey
The link to system.img at http://www.4shared.com/ now tries to install scareware on my PC and Kaspersky reports the web page trying to download a virus. Is there a mirror available?
EDIT - I managed to get Opera to download it. I've put the system.img in the Froyo_Joggler_2.2.2_v1.2.3 folder and re-uploaded it to http://www.mediafire.com/?a1ad9j24v433vlw
@asantaga - do you want to add this to the wiki or edit the first post?
psionguy
Post by psionguy »
Great image and working well, but how do you get english menu?
Winterhasarrived
Post by Winterhasarrived »
The chap who made squeeze player for Android says he may have a look at compiling it for x86 this weekend. Fingers crossed as its a great app.
mikeywilliams
Post by mikeywilliams »
Sound out problem:
The sound output socket at the back does not provide any output - all I get is a crackling sound and the internal speaker is not cut off.
Is this just my problem or does android not manage the sound hardware correctly?
Any way of fixing it.
BTW - Works fine in the built in joggler OS
This is the best release yet but I'm still having connection problems - although the Joggler shows it is connected & can browse the web I cannot connect to gmail or download from the Market. If I apply the market fix this gives me a temporary connection but it doesn't last. Android would be the perfect OS for the Joggler but it's very frustrating not being able to connect. Does anyone have any ideas? I already have ethernet turned off.
Woo hoo, I got it fixed! The problem (on my Joggler at any rate) was the system time. To fix it, make sure the auto setting for time & date is unticked under Settings. Next open Clock Sync & perform a sync. Then set it to auto-sync every 15 minutes. Market & Gmail now connect every time!
Winterhasarrived
Unfortunately the squeezeplayer author hasn't the time to mess about with the x86 stuff. Fair play to him and I'm impressed he took the time to look into it. His software works well on my advent Vega and phone so can strongly recommend it.
mikeywilliams wrote:Sound out problem:
I have the same issue here Mikey, no sound or mute when headphones are plugged in on this latest build it worked fine on the first build , I can remember using headphones on that build.
Can anyone else confirm this issue ?hopefully easy fixed.
mikeywilliams
Thanks. Glad it isnt just me.
Would be nice to get it sorted.
Did you use the chineese build from Asantagas link and adjust for English or did you use the Alindl method ? just in case that has something to do with it . :D
mikeywilliams
I used the Alindl image.
If anyone who didn't use that image please confirm if the output sound socket is working please.
Would be nice to get it sorted.[/quote][/quote]
Has anyone found a radio streaming app that works? The only one I've found is an old version of Resco Radio (latest version does not work on the Joggler) but the list of stations is quite limited. Tune In (RadioTime) also doesn't work.
Also, has anyone managed to get beebplayer to work? Mine has yet to successfully stream anything :-(
mikeywilliams
dwl99 wrote:Has anyone found a radio streaming app that works? The only one I've found is an old version of Resco Radio (latest version does not work on the Joggler) but the list of stations is quite limited. Tune In (RadioTime) also doesn't work.
Nope. I tried every radio app I could find.
Resco only found World Service and Radio London.
No beebplayer worked - just sat at buffering.
That and the non functioning sound out are the two main defects in an otherwise excellent system.
The Moon ebook reader is excellent BTW.
As is doggcatcher for podcasts.
yugo
Post by yugo »
Beebplayer streams fine for me using wireless connection. Havent tried any other radio streaming apps.
Have no sound output from jack either.
photize
Post by photize »
FLASH VIDEO ON ANDROID JOGGLER
Hi for those who are interested skyfire has installed on the latest from the app shop and works , I have played live video from livestation.com they also have a free tryout and a test page http://www.skyfire.com/en/support/video-site-check maybe a bit limited but if nescessary only 2.00 euros to buy !!! I'll keep playing
Mikey,
I used alindl image too, can anyone who is using the chineese link asantaga posted see if their sound jack mutes / outputs sound ok please.
Also beeb app (radio) is streaming fine over wi fi ( buffers for 30 secs ish first tho ) i used the link in this thread to download it though if that makes a difference.
I hadn't tried audio streaming, only video. Anyone got beebplayer to stream video?
yugo
Post by yugo »
Ah you meant video streams, doesn't work for me either.
nigelh
Post by nigelh »
The latest version of resco radio free worked fine for me. UK radio (lite) works ok, but i don't think beeb channels are included.
