koalauk
Re: new Android 2.2.2 Mijuu Build 1.2.3
Post by koalauk »
I am running this android on my 2gb non sdhc card no problem !
IanL
Post by IanL »
dwl99 wrote:You actually need an 8GB stick for the 4GB image to fit comfortably!
I agree, that may have been a better option but as the SD partition just fills whatever the remaining space is, that should not cause a problem with me booting should it? The ANDROID and DATA partitions are all 1GB as suggested.
Andy Mark
Auto-turn off screen after 1 min. ?
Post by Andy Mark »
1. How do I make the Joggler turn off the screen after a short time (1 min.) :?:
My screen is always on.....?
I am trying "Screen timeout" in Settings but it changes nothing (I still only get the minor auto-dimming after 10 sek.)
:arrow: A method that turns the screen 100% off is prefured.
(I'am using the custom Android 2.2.1 Build by asantaga....yes, I know ;) - works great for me with Pandora from Denmark !)
By the way:
2. The Android build's run a UK version of Market, how do I access the US Market on the Joggler: I whant to install 'Pandora Radio' from Market - how ?
3. Is there a way to run Squeezeplay under Android; worked for me with Ubuntu.
1. Try an app called Market Enabler to fool the device into thinking you are in the US.
2. Squeeze Player will never run on the Joggler due to the type of CPU it has (x86). I emailed the dev and he has no plans to compile a compatible version. Squeezeplay is the only thing stopping Android being perfect on my Joggler. I'm currently running Upnplay as an alternative and it's not bad.
Andy Mark
Post by Andy Mark »
dwl99 wrote:1. Try an app called Market Enabler to fool the device into thinking you are in the US.
OK. I will try that; thanks a lot dwl99.
danjog2
Post by danjog2 »
In case I missed it is there a pimped - ready to rock image of Android 2.2.2 available yet?
If not it sounds like a great idea.
jp_hero
Post by jp_hero »
danjog2 wrote:Hi
Yes sure is a newer version. We took the new image (1.2.4) from Mijuu added Google apps and then tweaked it a bit.
There are three versions in a new thread here http://www.jogglerwiki.com/forum/viewto ... ?f=2&t=196 read my first post and decide which version you want.
Some people are saying that 1.2.3 is more stable and more apps are installable so I would suggest trying it on a different stick first.
danjog2
Post by danjog2 »
Thaks very much, gonna give that a go now.
jaivuk
Post by jaivuk »
Hi guys, anybody tried to make some Microphone work together with some VOIP app such as Sipdroid?
I've made a disk image of Android 2.2 v1.2.3. It has been shrunk to 3.5GB so it should fit on all those undersized 4GB USB drives out there. If the Market doesn't work try the "market fix" as previously described. I think that this version of Android is better than 1.2.4 as it is more stable and will allow a wider variety of apps to run. You can download it from http://www.mediafire.com/?wotjcjzybv4w4 - sorry, but I needed to split it into 12 files to upload it.
russ333
Post by russ333 »
Thanks. I will give it a try. It would be great to get utube working
dwl99 wrote:I've made a disk image of Android 2.2 v1.2.3. It has been shrunk to 3.5GB so it should fit on all those undersized 4GB USB drives out there. If the Market doesn't work try the "market fix" as previously described. I think that this version of Android is better than 1.2.4 as it is more stable and will allow a wider variety of apps to run. You can download it from http://www.mediafire.com/?wotjcjzybv4w4 - sorry, but I needed to split it into 12 files to upload it.
if you upload it to my ftp, i can make the image available to download without having to use the online download services.
Fab, if you can pm me the ftp details I'll upload it. Although it's 2GB zipped!
i posted them in the other thread, thought you would spot it there :) it's
ftp://malus.exotica.org.uk/incoming/joggler/
Yep, I did - now uploading to your /incoming/joggler folder
rsjackson
Post by rsjackson »
Link to the zip file does not work for me , unless perhaps it is the work network stopping access. Just get a blank when clicked on and saving target of the hypertext does nto work either.
Any ideas what is wrong or I am doing wrong ?
rsjackson wrote:Link to the zip file does not work for me , unless perhaps it is the work network stopping access. Just get a blank when clicked on and saving target of the hypertext does nto work either.
which link? are you trying to download the zip that is being uploaded to my ftp? that's a write only incoming folder, and the upload isn't complete. When it is complete it will be moved somewhere where you can access it.
rsjackson
Post by rsjackson »
ahh , gotcha , thanks.
uploading with Filezilla but connection keeps dropping after a couple of hours. Will keep trying. Sigh.
i didnt realise my ftp incoming permissions allowed "overwriting". not very secure if it does. might have to change that. maybe split it into smaller parts?
