Hang on! Does the above process mean that those of us who don't have the palindrom patch adding Modeltype be affected when a new API key is issued?
Just asking' !
Just asking' !
It's all getting a bit "baby out with the bathwater" and "spoil the ship for a ha'peth of tar" in my humble opinion
atb
Ronnie
atb
Ronnie
Re: SqueezePlay OS (V3) - joggler brightness and strange pla
Well, it seems that in the ickStream case, this has created a big problem. Under the circumstances, I'd suggest it isn't made an integral part of Squeezeplay - but left as a patch for those who want to know their Joggler is an Openframe device.palindrom wrote: If you are creating a new release, please consider adding the JogglerUpdateModel applet too.
This app will identify our Joggler(s) as being an OF1 or OF2 device to the LMS which is essential for server-side applets.
From what I've seen on the Slimdevices forum, there are 3 Joggler users with no issues, and 1 with problems. If Roobarb wants to go through the approval process, fine. But seems a lot of fuss for very little gain.
Just my ha'peth worth.
There is no new API key used. The patch just using a long implemented feature.castalla wrote:Hang on! Does the above process mean that those of us who don't have the palindrom patch adding Modeltype be affected when a new API key is issued?
Just asking' !
If you are using the 7.9 nightly LMS you will see the device type displayed on the various info screens.
Changing the client type to OF1/2 should not create any problems with LMS.
But I understand the ickstream problem. It is caused because they are using the model and not the model name to evaluate the player.
Sooner or later they will ask you to pay for the service. And they should be happy that there is a method to distinguish between different squeezeplay implementations.
For my opinion they should implement true Joggler support ...
But if you arr already on 1.59 you could use my applet to change the type back to squeezeplay.
All I can say is that ickStream and Squeezeplay seem to register okay without the patch.
The API reference is to what the ickStream developers suggest should be done at the Joggler Squeezeplay end by Roobarb
I don't use 7.9 so I can't check what it gives as device type.
I do no mind roobarb! reverting the automatic identification.castalla wrote:All I can say is that ickStream and Squeezeplay seem to register okay without the patch.
That's why I provided the app to the benefit of those who want to use it.
Hi Castalla;castalla wrote:All I can say is that ickStream and Squeezeplay seem to register okay without the patch.
just so we are all on the same page: I am not sure what you mean by 'patch'.
This is my setup (which has problems w/ registering the Joggler Squeezeplayer):
Joggler running SPOS v30 with updated LMS to:
Logitech Media Server Version: 7.9.0 - 1415364188 @ Sat Nov 8 03:57:31 UTC 2014
Squeezeplayer version:
Player-Modell: SqueezePlay
Gerätetyp: OpenFrame1
Firmware: 7.7.2-r9710
*no* additional patches
And from what I understand from ManinaVan's feedback, he is running the same scenario, only w/ a slightly older LMS Version (7.9.0 - 1411...) - which does not report the 'Gerätetyp' - and for him, it seem to work.
-> I think, everyone will be affected by the problem w/ ickstream, as soon as he/she will run the latest SPOS build in Squeezeplayer (7.7.2-r9710) and any of the newer versions of LMS (i.e. > 7.9.0 - 1415364188)
This is all just my best guess.
*Update*
I think I get it now - by patch you mean this here, right?
And yes, I did update to that....roobarb! wrote:Just pushed v1.59 of SqueezePlay. Now includes a simplified (as in, there's no UI!) version of palindrom's JogglerUpdateModel applet. Your devices should automatically identify themselves as OpenFrame1 or OpenFrame2 devices......
Hi Roobarb: Is there a way that I can roll v1.59 of SqueezePlay back to the prior version and verify thus, if this created the problem?
Yep. That's it - palindrom initially provided a zip file, which Roobarb then incorporated in an update.
I never updated, nor I'd guess did the others who aren't having the problems you are.
Just for the records. I provided an applet to change the model and/or type of your device.
and I asked to include it into future releases of squeeze OS for Joggler(s).
The current release 1.59 is now providing the the changed type as default value.
You could use the applet now to change the type back to squeezeplay (the old default)...
http://www.jogglerwiki.com/forum/viewto ... 100#p23168
copy the content of the file to:
/opt/squeezeplay/share/jive/applets/JogglerUpdateModel/
and reboot...
Wouldn' that conflict w/ roobarb!s automatic applet?palindrom wrote:You could use the applet I provided to change the type back to squeezeplay...jogglerhase wrote: Hi Roobarb: Is there a way that I can roll v1.59 of SqueezePlay back to the prior version and verify thus, if this created the problem?
and reboot...
oh poop. I did.castalla wrote:I never updated, nor I'd guess did the others who aren't having the problems you are.
are all of you using ickstream?ilovemyjoggler wrote:oh poop. I did.castalla wrote:I never updated, nor I'd guess did the others who aren't having the problems you are.
Is there any HowTo available?
Is the type change causing any other problem(s) as well?
I just tried this - and it works!jogglerhase wrote:Wouldn' that conflict w/ roobarb!s automatic applet?palindrom wrote:You could use the applet I provided to change the type back to squeezeplay...jogglerhase wrote: Hi Roobarb: Is there a way that I can roll v1.59 of SqueezePlay back to the prior version and verify thus, if this created the problem?
and reboot...
Updated the player model to 'squeezeplay' with your applet, rebootet (not only restart LMS, but OS reboot was needed) and now it reports 'squeezeplay' again and most important - the Joggler Squeezeplayer is now registered to ickstream.
So, we also verified that this *is* the problem.
....phew...
Heiner
I tried the attaches script with "n" option direct after clean reflash. Working. But I needed to power off the joggler.jogglerhase wrote:Hi Palindrom;palindrom wrote:......
This bash installation script will automatic install and configure your AP
You only have to enter your SSID, password and your speed decision (802.11g/802.11n) .....
I am using the std. internal Joggler WLAN USB Stick. Everything works fine - but only when using wireless g mode.
If I use your script to switch to n mode, the AP function does not work, i.e. I can not access my network via the joggler, only through my std AP.
Any ideas why that is & how to fix it?
Heiner
Pleas try the attaches script (channel 1) please.
EDIT:
We need to wait for the bridge to be ready before we start hostapd
The attaches script will change /etc/network/interfaces accordingly
sudo mv /etc/init.d/hostapd /
sudo /opt/squeezeplay/bin/install_ap.sh
- install_ap.zip
- Updated script
- (2.66 KiB) Downloaded 488 times
Here's the link for ickStream: http://forums.slimdevices.com/showthrea ... post796363palindrom wrote:are all of you using ickstream?ilovemyjoggler wrote:oh poop. I did.castalla wrote:I never updated, nor I'd guess did the others who aren't having the problems you are.
THX for verifying. I can confirm. Please be sure to use lower case only: squeezeplay and not SqueezePlayjogglerhase wrote: Hi Roobarb: Is there a way that I can roll v1.59 of SqueezePlay back to the prior version and verify thus, if this created the problem?
and reboot...
....phew...
Heiner
This bash installation script will automatic install and configure your AP.....
EDIT:
sudo /opt/squeezeplay/bin/install_ap.sh....
I tried this new skript - including the prior mv.
And both befor and after your update of the post - no luck.
If I try n mode, no wireless comes up at all. (Even with shutdown and power off)
Going back to g mode fixes it.
Would still be great, if you could get n mode working...
I am just puzzeled, why it works for you??
Heiner
Hi Palindrom;palindrom wrote:.....I tried the attached script with "n" option direct after clean reflash. Working. But I needed to power off the joggler.
Please try the attaches script (channel 1) please.
EDIT:
I tried this now also on a fresh install (on my backup Joggler)
On this one, I do not get any option (g or n) working at all...
Can you pls confirm the steps needed again?
sudo apt-get -y update
sudo apt-get -y install hostapd
sudo apt-get -y install bridge-utils
copy 'new' install_ap.sh to /opt/squeezeplay/bin/install_ap.sh
give it 0755 rights
(enter ssid, pw, g/n)
sudo reboot
Power down & up again
Heiner
jogglerhase wrote:Hi Palindrom;palindrom wrote:.....I tried the attached script with "n" option direct after clean reflash. Working. But I needed to power off the joggler.
EDIT:
Test it -> Does not work for meCode: Select all
sudo apt-get -y update sudo apt-get -y install hostapd sudo apt-get -y install bridge-utils copy 'new' install_ap.sh to /opt/squeezeplay/bin/install_ap.sh give it 0755 rights sudo mv /etc/init.d/hostapd / sudo /opt/squeezeplay/bin/install_ap.sh (enter ssid, pw, g/n) sudo reboot Power down & up again
Heiner
If you have a new installed joggler you only need to copy the script to your joggler
recommended: /opt/squeezeplay/bin/install_ap.sh
or sudo nano /opt/squeezeplay/bin/install_ap.sh
and copy paste the script below...
then execute it
sudo chmod 755 /opt/squeezeplay/bin/install_ap.sh
it should ask you first for the parameters and then to enter the parameters ant downloading all needed modules. sudo reboot
#!/bin/bash
# /opt/squeezeplay/bin/install_ap.sh
MYTEMPFILE=/tmp/install.ap
HOSTAPDCFG=/etc/hostapd/hostapd.conf
INTERFACES=/etc/network/interfaces
MYSSID=
MYPASS=
MYPERF=
MYPERN=
function write_i () {
WLANMAC=`ifconfig -a | grep "wlan0" 2>&1 | awk -F\addr {'print $2'} | awk -F\ {'print $1'}`
WLANMAC=02"${WLANMAC: -15}"
echo -n "# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
#auto eth0
#iface eth0 inet dhcp
# The secondary network interface
#auto wlan0
#iface wlan0 inet dhcp
auto br0
iface br0 inet dhcp
#network 192.168.1.0
#broadcast 192.168.1.255
#gateway 192.168.1.254
#netmask 255.255.255.0
hwaddress ether $WLANMAC
bridge-ports eth0 wlan0
up /sbin/ifconfig br0 up
post-up /bin/sleep 10 ; /usr/sbin/hostapd -B /etc/hostapd/hostapd.conf
pre-down /usr/bin/killall hostapd
down /sbin/ifconfig br0 down
">$MYTEMPFILE
function write_g () {
echo "ctrl_interface=/var/run/hostapd
# Basic Config
macaddr_acl=0
auth_algs=1
# Most modern wireless drivers in the kernel need driver=nl80211
driver=nl80211
# Local configuration...
interface=wlan0
bridge=br0
hw_mode=g
channel=1
ssid=$MYSSID
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=$MYPASS
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP">$MYTEMPFILE
function write_n () {
# details see http://w1.fi/cgit/hostap/plain/hostapd/hostapd.conf
echo "# /etc/hostapd/hostapd.conf
# authoritative information and specifics are available here:
# http://hostap.epitest.fi/gitweb/gitweb.cgi?p=hostap.git;a=blob_plain;f=hostapd/hostapd.conf
# https://wiki.debianforum.de/WLAN-Access-Point_mit_hostapd_und_USB-Stick
# Basic Config
macaddr_acl=0
auth_algs=3
# WiFi B/G/N based on the Ralink RT2870 chipset (connected to the internal USB port).
driver=nl80211
# if you want to bridge the onboard eth0 and the wireless USB adapter's wlan0, this should work
interface=wlan0
bridge=br0
# yes, it says 802.11g, but the n-speeds get layered on top of it
hw_mode=g
# this enables the 802.11n speeds and capabilities
# ... You will also need to enable WMM for full HT functionality.
ieee80211n=1
wmm_enabled=1
wmm_ac_be_aifs=3
wmm_ac_be_cwmin=4
wmm_ac_be_cwmax=10
wmm_ac_be_txop_limit=0
wmm_ac_be_acm=0
# adjust to fit your location
# Here is the authoritative list of countries:
# http://www.iso.org/iso/country_codes/iso_3166_code_lists/country_names_and_code_elements.htm
country_code=DE
# let your AP broadcast the settings that agree with the above-mentioned regulatory requirements per country
ieee80211d=1
# makes the SSID visible and broadcasted
# adjust to fit your preference
ssid=$MYSSID
# this is how I set mine up
auth_algs=3
wpa=2
wpa_pairwise=TKIP
rsn_pairwise=CCMP
macaddr_acl=0
# self-explanatory, but not all channels may be enabled for you - check /var/log/messages for details
# also, make sure you survey your 2.4GHz environment, and find some uncluttered/uncrowded channels
# freq HT40- HT40+
# 2.4 GHz 5-13 1-9
# 5 GHz 40,48,56,64 36,44,52,60
channel=1
# these have to be set in agreement w/ channel and some other values... read hostapd.conf docs
# ... these can be tuned to specific capabilities per device/chipset
#ht_capab=[GF][SMPS-STATIC][HT40-][SHORT-GI-20][SHORT-GI-40][RX-STBC1][MAX-AMSDU-3839]
ht_capab=[HT40+][SHORT-GI-40][SHORT-GI-20]
# IIUC, this enables reauthentication for clients, so the passphrase doesn't have to be re-entered
#eap_reauth_period=3600
# ... my understanding... 3600 seconds = 1 hr, so your device would have to reauthenticate if it rejoined after 1 hr
# I have mine set quite a bit higher than 3600 seconds... so that my iPhone doesn't ask me to type in the password
# frequently...
# debugging output - uncomment them to activate; issue hostapd -d /etc/hostapd/hostapd.conf
# to get debugging info in visible/real-time form
#logger_syslog=-1
#logger_syslog_level=2
#logger_stdout=-1
#logger_stdout_level=2">$MYTEMPFILE
if [ -f $HOSTAPDCFG ]; then
MYSSID=`cat $HOSTAPDCFG | grep -oP "^ssid=\K.*"`
MYPASS=`cat $HOSTAPDCFG | grep -oP "^wpa_passphrase=\K.*"`
MYPERF=`cat $HOSTAPDCFG | grep -oP "^ieee80211n=\K.*"`
MYPERF=${MYPERF:-0}
fi
while true; do
echo
read -e -p "Enter SSID: " -i "${MYSSID:-myhotspot}" MYSSID
read -e -p "Enter passphrase: " -i "${MYPASS:-qwerty0987}" MYPASS
read -e -p "Use 802.11n performance(0 - no ,1 - yes): " -i "${MYPERF:-1}" MYPERN
if [ "$MYSSID" != "" ] && [ "$MYPASS" != "" ]; then break; fi
done
if [ ! -f "/etc/default/hostapd" ]; then
echo
echo installing packages
echo updating /etc/default/hostapd
sudo sed 's/^DAEMON_CONF=.*/DAEMON_CONF="\/etc\/hostapd\/hostapd.conf"/I' -i /etc/default/hostapd
fi
if [ ! -f $HOSTAPDCFG ] || [ "$MYPERN" != "$MYPERF" ] ; then
MYPERF=$MYPERN
if [ $MYPERF != 1 ]; then
echo creating 802.11g $HOSTAPDCFG
write_g 'MYTEMPFILE'
else
echo creating 802.11n $HOSTAPDCFG
write_n 'MYTEMPFILE'
fi
sudo mv $MYTEMPFILE $HOSTAPDCFG
sudo chown root:root $HOSTAPDCFG
sudo chmod 644 $HOSTAPDCFG
else
echo updating $HOSTAPDCFG
fi
echo access point conifguration
sudo sed "s/^ssid=.*/ssid=$MYSSID/I" -i $HOSTAPDCFG
sudo sed "s/^wpa_passphrase=.*/wpa_passphrase=$MYPASS/I" -i $HOSTAPDCFG
echo creating $INTERFACES
write_i 'MYTEMPFILE'
sudo mv $MYTEMPFILE $INTERFACES
sudo chown root:root $INTERFACES
sudo chmod 644 $INTERFACES
#sudo nano $HOSTAPDCFG
#sudo nano $INTERFACES
#ifconfig -a
# Basic Config
macaddr_acl=0
auth_algs=3
driver=nl80211
interface=wlan0
bridge=br0
hw_mode=g
ieee80211n=1
wmm_enabled=1
wmm_ac_be_aifs=3
wmm_ac_be_cwmin=4
wmm_ac_be_cwmax=10
wmm_ac_be_acm=0
country_code=DE
ieee80211d=1
ssid=MYSSID
auth_algs=3
wpa=2
wpa_passphrase=MYPASS
wpa_pairwise=TKIP
rsn_pairwise=CCMP
macaddr_acl=0
# freq HT40- HT40+
# 2.4 GHz 5-13 1-9
channel=1
# frequently...
#logger_syslog=-1
#logger_stdout=-1
auto lo
#auto eth0
#auto wlan0
auto br0
iface br0 inet dhcp
#hwaddress ether 02:0f:ff:ff:ff:ff
Tested with my OPEN PEAK joggler a minute ago.
Access Point issues
Hi Palindrom;
very bizarre...
I followed exactly the steps from the post above - on a freshly flashed Joggler (w/ SPOS3)
The script executed ok (installing the packages, creating the files aso)
But: It just does not work. Not the n mode and also not the g mode.
(Note: The Joggler & SPOS3 itself work fine: I can access access my network via LAN as well via WLAN...
Any ideas how to trouble shoot this?
Heiner
very bizarre...
Heiner
